LT1 head gaskets
LT1 head gaskets
someone was telling me the other day that LTX motors had problems popping head gaskets. I've never really heard about this being a problem, but I figured I'd ask if anyone had problems anyways. any suggestions (brand, type ect) on a new set of headgaskets?
Car: 1992 camaro
Axle/Gears: 3:73
Re: LT1 head gaskets
I have the fel-pro 1070 have not had a problem yet. You can go to the dealership and get the gaskets for a impala and it will bump your CR a little.And don't reuse the head bolts they are TTY bolts.
I wasn't going to reuse the bolts, I have a new set waiting already. thanks for the heads up on the impala gasket.
I also like Felpro for gaskets. Been impressed with the head gaskets, oil pan gasket, and valve cover gaskets they make for the LTX.
Quite easy to replace the head gaskets when you use a hayne's/chilton's manual as a guide.
I was told after I replaced my head gaskets that I should have got new bolts and should have had the heads looked over for cracks or warping. Oh well, everything is still working like it should and plan on re-building the engine in the future anyway.
another question on the head gaskets, I've noticed they have pushrod holes. can they pass as guideplates? I don't think it would be strong enough, but I figured I would ask.
didn't think so, oh well, I'll be buying some guideplates then.
ambainb
04-25-2016 09:21 PM
355tpipickup
08-27-2015 08:13 AM
NinjaNife
08-23-2015 11:49 AM
