need pictures of truck intakes in thirdgens!
hey guys, i'm needing some help from you guys that may have done the lsx swap using a truck motor. specifically, if you used a truck intake manifold, i need some clearance shots. i just picked up a 3" cowl hood and am hoping that a truck manifold would fit under it with room to spare. the reason is that i'm going to try to pick up a new edelbrock pro flo xt intake manifold, which sits at 10.2", and the truck manifold supposedly sits at 9"...so if one can fit the truck intake under a 3" cowl, then hopefully i'll be able to fit the pro flo.
worst case scenario, i'll get the new motor dropped in and sit an old truck manifold on the motor, but that's still a few days off. any help is SERIOUSLY appreciated!
Re: need pictures of truck intakes in thirdgens!
I can fit a vic jr, nitrous plate, 950 quick fuel carb, and a 14x6 air cleaner under my 4" cowl. Does that help? but mine is that glasstek cowl which is like an outlaw style where the cowl gets tall really fast compared to the smaller ones.
Car: 1987 Camaro Z28
Engine: 5.3L
Axle/Gears: 3.42LSD
Coming together. Redoing all the suspension right now. Next month is a stop at the paint shop
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: '89 Trans Am GTA
Engine: WAS 350 - now L92 (alum. 378/6.2L)
Transmission: WAS 700R4, now a built T56
Axle/Gears: 3.27 9-bolt
1987earthquake - it would probably help a lot if you could stretch a couple of pieces of masking tape from fender to fender across the engine compartment, like I did in my "truck accessories" thread...
Might make it a lot easier to see/judge how it lines up...
![thumbs up](https://www.thirdgen.org/forums/images/smilies/thumbsup.gif)
hey man i see you have a altrenater relocator on your engine would like to know where you got it or if you made it would like some specs on it if you dont mind
(NOTE: I haven't gotten a P/S pump yet, so I don't yet know about any clearance issues with the frame rail - that's the only remaining concern I have.)
Hope this helps.
![Smilie](https://www.thirdgen.org/forums/images/smilies/smile.gif)
I used the stock 1984 mounts with a 1" back adapter plate ... I am going to use a pancake compressor and mount it up on the passenger side...
2 1/2 should clear easily .. I am going to try and make a custom 1 1/2 cowl induction scoop for mine.
Terrell351
06-13-2021 01:13 PM
NBrehm
08-25-2015 11:49 PM
Street Lethal
08-12-2015 11:33 AM
