Beating a dead horse - LQ4 exhaust manifolds
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Situation: Have LQ4 that came from a 2003 G3500 van. It's going into the '57 and will get shoebox swap headers.
Also have LS1/4L60E from a 2000 Camaro that will go into Berlinetta #1, didn't come with exhaust manifolds (had headers, and 4th gen headers don't fit in 3rd gens - besides, the seller had already sold the headers).
I know the truck LQ4 exhaust manifolds don't fit in 3rd gen swaps, but how about van LQ4 manifolds? The frame rails are narrower (or at least, had been in the past) on vans than they are on trucks. These manifolds looked pretty tucked in to me, but I don't have 4th gen LS1 manifolds to compare them to.
I could pull the headers out fo Berlinetta #2 and see if the manifolds would fit, but hey, that's a lot of work.
Pic of the LQ4 van manifolds while still installed:
Comparison pic of the passenger side header:
I used to have LS1 exhaust manifolds, took pics before I let them go:
https://www.thirdgen.org/forums/atta...anifold-ds.jpg
If anyone has truck LQ4 manifolds they could compare to these, let me know if I'm totally off-base.
Engine: LS1/LQ4
Well, can't blame a guy for trying.
Guess they don't tuck in like the f-body manifolds do.
Engine: LS1/LQ4
If Archimedes can move the world with a long enough lever, perhaps I can use truck exhaust manifolds in a 3rd gen if I have a big enough hammer. . .
I know, headers would be better. Keep hearing horror stories when using a 4L60E.
Car: 1987 Trans Am
Engine: LQ9/L92
Re: Beating a dead horse - LQ4 exhaust manifolds
I'm really curious to see what a set of LS4 (fwd) manifolds look like in these cars. Budget means no headers for me and I'm going with an auto (also means no headers). a BFH makes almost anything possible, but I'm trying to stay away from that route too...
Car: 1987 Trans Am
Engine: LQ9/L92
curiousity killed the cat, but has anyone around here tried the manifolds off of a G8? They look pretty compact according to the shot of em I found on LS1tech:
http://www.ls1tech.com/forums/pontia...tall-pics.html
Engine: LS1/LQ4
Just a guess, but the distance from the head mounting surface to the outside edge of the flange on the passenger side is pretty wide. Doubt it would clear the frame rail.
I haven't seen this manifold measurements thread Pocket mentioned.
On Probation
Engine: several
Transmission: none
Axle/Gears: none
If you flip them, for a front exit, that gives you a good excuse to add a turbocharger. If you had a passenger side exhaust manifold from a '00 Z28 SS, that fits very well on the passenger side of my '84 Trans am LQ4. Too bad for you that you sold and shipped that item to me. :-) So, the question now, in my mind, is could we fit an Edelbrock shorty header in there on that side, in these older cars? And since these manifolds are the shizzle for LSx Fieros, would the edelbrock shorties fit there? Frustrating, ain't it?
On Probation
Engine: several
Transmission: none
Axle/Gears: none
BTW, IF you're very sure that the van driver-side manifold tucks closer than the pickup truck version, I could sure give it a new home. Enough to trade you the above-mentioned SS passenger side piece for it.
86CamaroDan
09-29-2015 10:08 PM
