LT1 Fuel line question
Car: 1987 Trans AM
Engine: Twin Turbo 6.0 LS2
Hey guys, I'm in the middle of a LT1 swap into my 1987 Trans AM. The TA use to be a carb. I've heard i need to replace all of my lines from tank to engine. However my lines are metal already. I'm going to guess they can handle the LT1's FI. I believe there may be some rubber coming off of the sending unit which i have to replace along with the pump.
So i guess my question is, will those metal lines handle the pressure of FI?
Thanks!
Thanks!
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
If originally EFI, the rubber can handle it. If originally carb, you need to at least change out the rubber, but the metal can handle it.
Engine: LS1/LQ4
Out of curiosity, which was yours, carb or TPI?
I may have over stated it, as all 87's had the in-tank electric fuel pump, and I'm not sure if the carb cars had the same rubber line or not as TPI.
theshackle
03-05-2017 06:37 PM
AkDrifted
08-17-2015 07:45 PM
