LQ4 CR w/ milled heads
Engine: Cammed 6.0L LSX
Re: LQ4 CR w/ milled heads
I had my heads milled, can't remember the exact specs on how much was milled, but it bumped my CR to 10.6x:1 with 317 heads, but I have aftermarket pistons (Mahle forged). They're not flat top pistons...I'll have to look at my build sheet and see if the mill number is on there. I posted all the engine specs in my swap thread I think it's on page 3.
Ummm its not off topic, I was hoping to see something on your list for the 317 heads, which I don't see unless I am blind?
On Probation
Engine: several
Transmission: none
Axle/Gears: none
First, It looks like I've offended you. If so, I apologize, that was NOT my intent. Second, once you change the pistons, it's no longer an LQ4. The pistons are the only thing that really differentiate the LQ4 compression from the LQ9/LS2 compression. The 317 heads are the leftmost column that's right of the red line, on my "page 2".
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
L92 heads don't use a LQ4 head gasket, you'd need an LS3 gasket or similiar.
On Probation
Engine: several
Transmission: none
Axle/Gears: none
I'm aware of that, which is why I noted that I had gotten lazy and proceeded on that false assumption. But if you choose a slightly thinner gasket to compensate for the slightly larger bore, the resultimg compression will still be so close to what I listed, too close to merit thinking about.
cabech984
10-28-2008 05:07 PM
