Carbureting my 96 LT1
I have an 96 LT1 that i got out of a Buick Roadmaster. I dont want to use the FI i would rather have a carb. I know what to do as far as intake and carb. i'm not sure what to do as far as ignition. i know the optispark distributor wont work, once the proper manifold is on the engine, can a normal distributor on the back of the engine be used? or would i have to use something like a belt driven distributor?
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Carbureting my 96 LT1
http://www.summitracing.com/parts/NAL-24502592/
There is a optispark block off plate available to seal the drive hole when you take the Opti off
Mike:
I just finished the same installation on my 1973 datsun 240z. I used the GM intake manifold. Removed the optispark and bought a GM cover plate. I already had an electric fuel pump......installed an pressure switch to kill the pump if the engine died. I used and MSD distributor and fabricated my own plug wires. I bought timing mark tapes from MSD and a top dead center finding tool to mark the pulley damper. I used a rochester quadrajet with an electric choke.........but the intake manifold will accept most 4 barrel carbs..........very sweet in a 2500 lb car
2012sergen11
10-13-2015 07:38 PM
96, 96lt1, camaro, carb, carberated, carburated, carbureted, carburetor, distributor, engine, engines, intake, lt1, manifold, top
