? about truck manifolds flipped
Car: 91 camaro rs
Engine: 355, blowthru, 78mm turbo
Transmission: th350, art carr converter
Axle/Gears: stock 7.5, 3.23s, minispool
what part/parts dont gen III truck manifolds clear? does the passenger side fit and the drivers side hit the steering box? or is there other points of interferance???
(talking about flipping them around pointing towards the front for turbo use like 98-02 cars do..)
if the steering is the only part they dont clear id like to do rack and pinion and use these manifolds...
if anyones got pics showing where/what they dont clear thatd be extremely helpful!
thanks, Keith
thanks, Keith
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
If I didn't have headers mounted already, I'd mock up my LQ4 manifolds for you.
They do kick out a good bit and down.
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: ? about truck manifolds flipped
If I had a pair, I could try this tomorrow. Seriously. I'm doing it the other way, rear-turbo, for emissions legality. The turbo is more of a restriction than the exhaust manifolds, so I'm using the '00 Z28 exhaust manifolds turned normally, into a not-yet-fabricated custom Y-pipe, into a 3" cat in the LG4-cat-location, then 3" over the exle, then the turbo in place of the muffler. This has been patented by STS, but they're overpriced, so I'm doing my own. That's legal, I just can't sell my copy because of the patent. By not putting the turbo between the manifolds and the cat, I stay 50-state legal.
Car: 1987 Formula 350
Engine: 6.0 boost and smak
Transmission: 4l80e
Axle/Gears: 9bolt 3.27
the flanges hit the frame rails.... pretty bad, I tried them before my 02 f-body's...
Car: '89 Trans Am GTA
Engine: WAS 350 - now L92 (alum. 378/6.2L)
Transmission: WAS 700R4, now a built T56
Axle/Gears: 3.27 9-bolt
Car: 91 camaro rs
thank you guys, thats kind of what i thought.... oh well worth a shot
sailtexas186548
02-17-2017 04:07 PM
86CamaroDan
09-29-2015 11:08 PM
