fuel fittings
Car: 91 Formula
Engine: lq4
Transmission: t-56
fuel fittings
ok, so i have been searching all over the web, what is this saginaw fitting that is supposedly on the fuel lines of tpi cars. i want to go from the stock 3/8 hard line to the lsx fuel rail, which i got a connector for the rail, but its -6 an. how can i adapt that to the stock thirdgen fuel line?
Car: 1989 IROC-Z, 1979 Malibu Classic
Engine: LSx 5.3
Transmission: MN12 6-speed, 4L60E
Axle/Gears: 4th gen 3.42
Re: fuel fittings
This might be what you're looking for, I think one is 16mm and the other is 14mm. I'm not completely sure on this but someone else might chime in here soon.
http://www.holley.com/9894DBHERL.asp
http://www.holley.com/9894DBJERL.asp
Car: '89 Trans Am GTA
Engine: WAS 350 - now L92 (alum. 378/6.2L)
Transmission: WAS 700R4, now a built T56
Axle/Gears: 3.27 9-bolt
Re: fuel fittings
Originally Posted by dynodanmanda79
...I think one is 16mm and the other is 14mm....
Re: fuel fittings
Talking about fuel lines..........
Can the flares on the LS1 fuel/brake lines used for the quick disconnect be remade on brand new lines ? Is there a special flaring die for that ?
I would like keep the fittings stock on the LS1 at the engine and fuel tank, but use my 3rd gen lines but make them the same as the LS1 at the 2 ends.
I thought about using compression fittings at the 2 ends and mating the LS1 ends to the 82's lines but heard that was a bad idea.
Sorry for hijacking ur thread.
Car: 91 Formula
Engine: lq4
Transmission: t-56
Re: fuel fittings
i'll post up pics if it'll help when the stuff gets here, but what i think i'm doing (in theory) is that with the above adapter threaded into the original thirdgen hardline right at the firewall, i can thread a -6 an line on to that. then i already have another adapter i got for the -6 an to the gm quick connector on the fuel rail. its a russell fitting at the rail, i can check the p/n when i get home tonight. haven't even looked at the tank yet though, i want to get the front end stuff handled before i make any bigger mess in my garage.
Engine: Cammed 6.0L LSX
Re: fuel fittings
So if I'm understanding this correctly, those fittings are all you need to connect the stock 3rd gen fuel lines to the LS1 fuel rails? Or does your fuel regulator go in between the two?
Car: 91 Formula
Engine: lq4
Transmission: t-56
Re: fuel fittings
i'm also swapping in the 4th gen tank, so the pressure is all taken care of back there. guess it'd be the same for the vetter filter mounted back there though. if you are running a regulater and a return line, you'd need to use the smaller adapter for the 5/16 return, then the same -6 an line and quick connect adapter. i am just running a returnless system.
Car: 1988 IROC-Z, 95 Z-28
Engine: 357, 350 LT1
Transmission: Built 700-R4, 6-Speed
Axle/Gears: 2.73 Peg Leg, 3.42 Posi
Re: fuel fittings
the russel fitings for the gm quick connect to -6 are
640940
640930
And the two adapters you need for the stock third gen hard lines are
9894DBJERL
9894DBHERL
Hope that helps
640940
640930
9894DBJERL
9894DBHERL
Hope that helps
Re: fuel fittings
To help you better explain the situation to me, I am using the stock 3rd gen tank with a bigger fuel pump, the stock 3rd gen fuel lines, the LS1 fuel rails, and an Aeromotive regulator.
Re: fuel fittings
Well the LS1 will only need one of the fittings I am refering to since there is not return. The quick connect is the connector that snaps onto the fuel rail from the original fuel line. The adapter has that on one end and converts that to a regular -6 an fitting or you can use a JIC fitting as well.
LMK
If you need more help
LMK
Engine: LSx 5.3
Re: fuel fittings
Explain what the GM quick connect is please. I'm not sure what you're referring to.
This is a GM quick disconnect fuel fitting and connects to the LS1 fuel rail, this particular one from Russell has 6 an threads.
evilstuie
01-09-2020 08:29 PM
R3500
08-17-2015 12:16 PM
