91 Z 6.0 turbo project
Old 03-24-2009, 08:03 PM
82z28man's Avatar
Car: 91 Z28
Engine: 6.0 LSX Single turbo
Transmission: 4l80E
Axle/Gears: Moser 9" 3.55
Just thought I would show you guys what i've got going on, Im building a 91 Z with a 6.0 LQ4, T56 and a single T76 turbo.
I allready painted the engine bay,modified the lower radiator support to mount the intercooler and moved the radiator about an inch back. I've got the motor and trans in, I dropped the tank tonight to start on a dual intank pump set up and I will be starting the turbo build as soon as a flange comes in that im waiting for. Im shooting for no less than 550 RWHP.
Old 03-24-2009, 08:20 PM
89RS305TTops's Avatar
Car: 87 Camaro Z28
Engine: LB9
Transmission: 700-R4
Re: 91 Z 6.0 turbo project
My god that Z's gonna be fast!
Im definetly gonna be watching this!
Old 03-24-2009, 11:12 PM
87CIZ's Avatar
Car: 88' Iroc-Z
Engine: LQ9
do you have any pictures of the radiator support modification? I'm doing the same thing except my lq4 i bought ended up being an lq9 so i'm getting a different set of pistons to lower the compression.
Old 03-25-2009, 08:00 PM
On Probation
TPI TERR's Avatar
Car: 87 IROC-Z
Engine: LsX
Transmission: MN12 6speed
Axle/Gears: 3:42
nice!
Old 03-25-2009, 08:09 PM
87SnowFlake's Avatar
Car: 87 IROC-Z
Engine: jasper 350
Transmission: 700R-4
Axle/Gears: 2.73 posi
Holy Shinikies! thats sick!
Old 03-25-2009, 09:20 PM
82z28man's Avatar
Car: 91 Z28
Transmission: 4l80E
Ive allready got the inercooler mounted so I cant really show you exactly, but basically underneath where the condensor would go theres a hump in the lower radiatior support. So I cut and welded it in two spots where the intercooler mounting bungs are. For the radiator I extended the lower support just enough so it would fit. Its not too hard and it still looks factory. I will get you pics of that though. I started on the turbo header tonight and just about have it done, I will post some pics.
Old 03-26-2009, 08:45 PM
82z28man's Avatar
Car: 91 Z28
Transmission: 4l80E
Heres are a few update pics and a pic of the lower support for 87ciz.
Old 03-26-2009, 08:52 PM
86LT1's Avatar
Car: 1986 Camaro IROC-Z
Engine: 357 LTx
Transmission: T-56 6spd
Axle/Gears: GM 7.5 10 bolt with 4.10 richmonds
looks awesome so far! can't wait to see the finished result!! Good Luck!
Old 03-29-2009, 06:53 AM
BCdawg57's Avatar
Car: '91 Z28, '13 Civic EX-L
Engine: 355 LT1, 1.8 I4
Transmission: T56, 5spd auto
Axle/Gears: 10 bolt 3.42(as long as no breaky)
Old 03-29-2009, 10:34 AM
87CIZ's Avatar
Car: 88' Iroc-Z
Engine: LQ9
what are the dimensions of your intercooler? That looks like a perfect fit. I take it there wasn't a way to flip some stock manifolds around? I've got some ls3 manifolds off of a vette i was hoping i could flip around and they would clear.
Old 03-29-2009, 10:39 AM
Rich2279's Avatar
Car: '98 Mustang GT
Engine: '03 4.6L
Transmission: T45
Axle/Gears: DK
Nice plans you have going there.
Old 03-29-2009, 07:32 PM
82z28man's Avatar
Car: 91 Z28
Transmission: 4l80E
The intercooler is a 31x12x3 that I got off ebay pretty cheap. It fits great and actually seems to be of good quality. You could probably flip some manifolds forward and do it that way if you either relocate the alternator or use a corvette accy. drive. Theres a ton of room in front of the engine but I didnt really want all that heat between the radiator and engine, so im glad I did it the way it is.
Old 03-29-2009, 07:35 PM
82z28man's Avatar
Car: 91 Z28
Transmission: 4l80E
I have the turbo hot side done. Now I just need to clean up the welds and wrap it up. Here are a few pics.
Old 03-30-2009, 01:38 PM
NemeSS-TyranT's Avatar
Car: 02 SS
Engine: 408 TT (1108rw-93/m1)6700rpm
Transmission: TH400(slipping)
Axle/Gears: 12bolt/3.42(whines😠)
very nice!
i would wrap the starter with a blanket as well as the dp
plug access looks like it may be a lil hard from the top for 2,4,6
going in thru the bottom? or make your dp a 2 piece with vband, to remove for easier plug access.
0.02$
Old 03-30-2009, 06:24 PM
82z28man's Avatar
Car: 91 Z28
Transmission: 4l80E
The angle of the picture makes the plug access look worse than it actually is. It shouldnt be too bad with a good set of gloves if im doing it while its hot. I will definetly take your advice and wrap the starter. Thanks for your input.
Originally Posted by NemeSS-TyranT
very nice!
0.02$
Old 03-30-2009, 06:56 PM
RevItUpZ28's Avatar
Car: '91 Camaro Z28
Engine: 383 Vortec HSR
Transmission: Pro-Built 700-R4;Vig 4000 stall
Axle/Gears: Moser M9 9" / 3.89
Subscribing for pics! That's awesome!
Old 03-30-2009, 08:01 PM
BadAzzGTA89's Avatar
Car: 1989 GTA
Engine: LQ9
Very nice setup!
Old 04-11-2009, 12:29 AM
T TA 355's Avatar
How much did you spend on materials for the hotside?
Old 04-11-2009, 07:30 AM
FirehawkSS's Avatar
Car: 87 Firebird,
Engine: lq4
Transmission: gto t56 (mn12)
Yea I'm interested too. If you could keep cost somewhat reasonable I wouldn't buy the 3rd gen swap lt's and put that money towards a decent turbo setup.
Looking good so far!
Old 04-11-2009, 10:02 PM
82z28man's Avatar
Car: 91 Z28
Transmission: 4l80E
bump
Old 04-12-2009, 11:12 AM
Blownz28man's Avatar
Car: 92 25th anv z28
Engine: 346 TC78 Turbo
Transmission: 4L80E
Axle/Gears: 3.25 9"Nodular, Strange axles
You have all my attention! Looks good. Your giving me motivation to start mine.
Old 06-03-2009, 02:33 PM
T TA 355's Avatar
Any Progress?
Old 06-03-2009, 02:58 PM
camarozz383's Avatar
Car: 1989 camaro rs
Engine: ls 5.3 carb
Transmission: t56 six speed
Axle/Gears: 3:73
That is a sweet project! looks nice.
Old 06-04-2009, 09:25 AM
coolmarocrzy's Avatar
Car: 85 Z28
Engine: LS
Axle/Gears: 9inch/3.50 gears
Very good job on the pics, they are worth a thousand words.
Old 06-04-2009, 09:31 PM
82z28man's Avatar
Car: 91 Z28
Transmission: 4l80E
Its taking me longer than I thought but im getting alot done. Its running pretty good but I still have alot of tuning to do on it. I did LS1 brakes all around along with an LS1 axle. I also repainted the front clip so that took some time. The car is pretty dirty but heres a pic of what it looks like now
Old 06-04-2009, 10:03 PM
fast82z's Avatar
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
Axle/Gears: S60 3.54's
I'm thinking of doing just the same thing, all depends on if my buddy can buy his truck back from the insurance people and sell me the stuff out of it. What are you using to tune on that? Is it much good or easy? I have a Big Stuff 3 on my car now, but haven't seen any LSX tuning stuff.
Old 06-05-2009, 09:39 PM
82z28man's Avatar
Car: 91 Z28
Transmission: 4l80E
I have HP tuners professional version and im very happy with it. I wouldnt say its easy, but its getting easier the more I get into it. Im tuning it in speed density and im making pretty good progress I would say.
Old 06-05-2009, 10:10 PM
fast82z's Avatar
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
Did you just edit out the MAF from the computer then, kind of like I've heard you can do with post-cat o2 sensors?
Old 06-06-2009, 06:36 PM
82z28man's Avatar
Car: 91 Z28
Transmission: 4l80E
Well kinda, you read your current factory or MAF tune to the software then you write over it in a 2 bar map speed density operating system. Then you would tune your VE table in place of the MAF, then the OS adds a boost enrich table which is nice as well. I believe Hp tuners is the only software that makes it that easy to switch to speed density, I think it would take alot more work if you had another software but I could be wrong, this is the only software i've worked with.
Old 06-07-2009, 10:20 PM
Transmission: 4L80E
Really like the turn out! You have any more pics how you routed the intercooler piping? You think the down pipe would fit a car w/ac? Any woreds of advice? I'm gonna start a build with a t76 on my ls1
Old 06-22-2009, 08:08 PM
5literTPIterror's Avatar
Car: 91 camaro rs
Engine: 355, blowthru, 78mm turbo
Transmission: th350, art carr converter
Axle/Gears: stock 7.5, 3.23s, minispool
this looks like a nastyyyy setup! how did i miss this? is it posted under power adders? i didnt see it there.
i just broke at least 1 connecting rod in my turbo camaro (gen 1 sbc) and am thinking of either a 5.3 or 6.0.
i believe a 5.3L would be slightly more effiecient through my .96a/r t-4 housing and would still easily meet my hp goals of 550+/-rwhp.
im using a tc-78.
great job man!
Old 06-22-2009, 08:54 PM
BlueZee28's Avatar
Engine: Cammed 6.0L LSX
That looks great. Care to tell us what the cam of choice is?
Old 06-23-2009, 04:18 PM
T TA 355's Avatar
What fuel rail did you use?
Old 06-24-2009, 09:23 PM
82z28man's Avatar
Car: 91 Z28
Transmission: 4l80E
Yes, i will get more pics of everything very soon including the outside of the car. I dont think you could go with ac with this set up, although if you mounted the intercooler in front like other people do and had the radiatior mounted like factory you could easily put the turbo between the radiator and engine, theres actually quite a bit of room. And the you could possibly get the downpipe out the back if you had a tubular k member and ran it underneath some how.
Its an EPP blower cam. Im happy with it, and it sounds great. It did make the idle tuning a little bit of a chore for me but its getting there.
Thats a professional products rail set up, you cant beat it. Its pretty cheap, looks great and even comes with a boost referenced regulator since its made specifically for the early ls1 corvettes that had a return line.
Old 06-24-2009, 09:31 PM
BlueZee28's Avatar
Can we get some audio and/or video footage sometime soon?
Old 07-05-2009, 07:02 PM
82z28man's Avatar
Car: 91 Z28
Transmission: 4l80E
Well here are a few new pics, its pretty much finished up for now.
Old 07-05-2009, 07:04 PM
82z28man's Avatar
Car: 91 Z28
Transmission: 4l80E
Old 07-05-2009, 07:37 PM
TGO - 10 Year Member
//<86TA>\\'s Avatar
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
:drool:
Old 07-05-2009, 08:44 PM
JTNKTZ's Avatar
Car: 1991 Camaro RS/1989 Vert RS
Engine: 355/350
Transmission: T-5/T-5
Axle/Gears: BW9bolt3.45posi/3.23 Posi
What was the total cost including engine, trans turbos tubing and such?
Old 07-06-2009, 11:11 AM
MaxxMitchell's Avatar
Car: 87 Firebird
Engine: 5.3 76mm
Transmission: Rossler TH400, PTC converter
Axle/Gears: Strange 12bolt, 3.08s
Looks good. Im sure you will make the power you are wanting, reminds me of my set up.
Old 07-06-2009, 02:15 PM
1bdbrd's Avatar
Car: 1991 Trans Am
That looks amazing. I can't stop looking at this thread. Hats off to you!
Also, you mentioned ealier in the thread about building another setup over the winter, any ideas on how much you would charge for something like that? Depending on price I would have to give this some real thought.
Old 07-06-2009, 05:18 PM
  #42
FirehawkSS's Avatar
Car: 87 Firebird,
Engine: lq4
looks awesome. Are you worried about heat warpage on the crossover pipe? There is going to be a lot of heat going through that beast. And how are the exhaust flanges holding up? They look nice and thick but i would check into slotting them between cylinders to see if it might help you with flange warpage.
Old 07-06-2009, 08:04 PM
  #43
cam-'s Avatar
Car: Camaro
Engine: 6.2L
Nice job man. Dyno predictions?
Old 07-07-2009, 07:06 PM
  #44
82z28man's Avatar
Car: 91 Z28
Transmission: 4l80E
Thanks to you I had some vision, your build up made mine go alot smoother knowing that someone has allready done it this way.
I would but the only problem would be all the different transmissions would effect the routing of the crossover. I could possibly make a turbo header and have you just make a crossover frm the other side. Just keep in touch.
So far so good, everything is wrapped really good with eaxhaust wrap but i'll just keep an eye n it.
Im planning to end up at abut 10lbs of boost. I've seen ls1's with 10lbs running from 550-600rwhp at that boost level so i guess it depends how aggressive I want to go with the tune. But i'd like to be somewhere in that range.
Old 09-06-2009, 01:39 AM
  #45
T TA 355's Avatar
What manifold did you use on the ds?
Old 09-06-2009, 06:06 PM
  #46
82z28man's Avatar
Car: 91 Z28
Transmission: 4l80E
Its a non EGR f body manifold.
Old 09-07-2009, 08:46 AM
  #47
fun Pain's Avatar
Car: 1987 Formula 350
Engine: 6.0 boost and smak
Transmission: 4l80e
Axle/Gears: 9bolt 3.27
I shouldn't look at this, its like looking at my own future !!!!
read my sig, you can see my future too....
Nice build
are you still running the 72cc 317's?
if so you do will probably make more power then ls1's at that boost level because you can run more timing, I have seen it first hand, multiple times....10.45:1 (ls1) to 9.41:1 (lq4)
5literTPIterror; I feel your pain, if you built the turbo setup, this is cake (6.0swap)
Old 09-07-2009, 09:14 AM
  #48
82z28man's Avatar
Car: 91 Z28
Transmission: 4l80E
Nice build
I know, Im up to 18 degrees of timing safely at WOT, as opposed to ls1 guys that seem to need meth at that much timing in boost.
Old 09-16-2009, 12:54 PM
  #49
gadocbar's Avatar
Car: 86 Z-28
Engine: 350 VORTEC
Axle/Gears: STOCK
i just bought a lq4 for my 3rd gen could u tell me what intake, fuel parts. u used
Old 11-02-2009, 08:58 PM
  #50
T TA 355's Avatar
What size pipe did you use on the log?
Quick Reply: 91 Z 6.0 turbo project
