ls1 in 92 Camaro
Car: camaro rs (a tru sleeper)
Transmission: turbo 350
ls1 in 92 Camaro
hey im about to a 92 camaro with a ls1 in it....my two questions are how would i go about putting ac in the car????? and also the guy told me the speedo doesnt work...so how would i go about getting that to work???
Car: 02 SS
Engine: 408 TT (1108rw-93/m1)6700rpm
Transmission: TH400(slipping)
Axle/Gears: 12bolt/3.42(whines😠)
Re: ls1 in 92 Camaro
u will have to notch the factory kmember and modify, i think there is a kmember for use with ac, i use paracing, but ac is not of a concern to me. i will have to verify next time to see if ac works with paracing.
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
If you don't want to notch the k-member:
https://www.thirdgen.org/forums/ltx-...x-swap-ac.html
I have verified it will clear ( https://www.thirdgen.org/forums/ltx-...ointing-2.html post #63), but for better or worse, went ahead and notched the k-member so the factory f-body AC compressor can be used. So, the bracket kit, compressor, and belt are now available.
Either way, you're going to have to have custom lines fabricated to mate to 3rd gen components, unless you swap in a complete 4th gen AC system.
