GTO LS2 M6 into my 92, any unique problems?
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
1 Post
Car: 92 Camaro RS
Engine: 305 TBI
I know where I can buy a complete 30,000 mile 2005 GTO LS2 with M6 attached with complete wiring harness for $4000, is there anything strange about GTO engines and trans. that would make this swap harder than say a LS1 M6 from a 98/02 Camaro? This will be going into my 92 Camaro with 305 & T-5. Do I need to swap the oil pan for a Camaro pan? Is $4000 a good price? And I read something about LS2's burning a lot of oil, anything to that?
Car: '89 Trans Am GTA
Engine: WAS 350 - now L92 (alum. 378/6.2L)
Transmission: WAS 700R4, now a built T56
Axle/Gears: 3.27 9-bolt
Re: GTO LS2 M6 into my 92, any unique problems?
1 Post
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
I haven't heard anything about LS2s burning oil...? And the GTO never had a torque arm setup I don't think, so that may cause a problem. Theres two ways around it, as it uses a T56 IIRC. You can get an aftermarket torque arm and crossmember setup that mounts the torque arm TO the crossmember (you'll need a new trans crossmember anyway to mount the T56 i think) or you can get an F-body T56 and use the torque arm on your car now.
