Heads from a 96 B-body or a 95 F-body??
Old 02-27-2009 | 01:30 PM
turners1362's Avatar
Car: 86 Z28
Engine: 355
Axle/Gears: Stock 3.42
Is one head better than the other, as far as performance? LT1 B-body heads are cast iron and the F-body's are aluminum. Basically I'm just curious if there is any benefit to the Aluminum heads other than weight savings.
Thanks,
ST
Old 02-28-2009 | 03:23 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: Heads from a 96 B-body or a 95 F-body??
On a stock LT1, they almost balance out... the iron heads flow about 15-20cfm better, but the aluminum heads have smaller chambers with a bit better chamber design. The iron heads will get more air into the engine, but the aluminum heads will burn it better with a slightly better design and more compression.
Its almost a wash if its an otherwise stock LT1, but I'd go for the aluminum heads if you have to choose. LT1 engine LOVE lots of compression!
92projectcamaro
01-18-2016 09:00 AM
Uglybronco
South Central
10-25-2015 10:22 AM
z28guy134
09-02-2015 12:50 AM
zayne0
08-24-2015 08:22 PM
