LT1 steam pipe temp?
1 Post
Car: 1992 z28
Engine: 383 LT1 in the works
Transmission: T-56 in the works
Axle/Gears: 3.73 in the works
Anyone have any idea how hot the steam pipe is that runs from the back of the heads to the TB?
I wanted to use SS braided lines similar to a carb fuel line setup... would it be too hot or is it ok? some lines i see are good up to 300 to 400F.
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
1 Post
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: LT1 steam pipe temp?
It will get as hot as any other hose in the cooling system... rad hoses, heater hoses, etc.. maybe a few degrees higher, just because of location, but not much more.
codeysabatini
11-10-2015 04:07 PM
