Question about LT1 Swap Wiring
Car: 1991 camaro rs
Engine: current tbi305 swapping to 94 lt1
Re: Swaping LT1 1994 into a 91 305 tbi rs
ok i am pretty new at engine swapping my names jacob i have a 91 rs with 305 tbi ....k ive taken the engine out also tranny and the rear end and fuel tank..................and in place i would like to put a 94 lt1 engine and tranny rear end and fuel tank and lines they came off a 94 z28 i have the whole car btw figure that might help but dnt have money
to buy a painless wireng kit i cut most of the wires coming out of my bulk connecter to splice with the lt1 pcm harness ........... but im still not completely sure
im doing it right and would appritiate alittle in put please and thank you ~jacob~
![](https://www.thirdgen.org/forums/images/smilies/go%20crazy.gif)
![crazy](https://www.thirdgen.org/forums/images/smilies/crazy.gif)
Car: 87 Trans Am
Axle/Gears: Not enough
Hi jacob, seems your kinda new round here so I'll see if I can help you. As to the wiring, at the top of this section you'll see a couple of stickies. I believe its the second one that deals w/lt1s. There is a link in the post that will give you detailed information on the lt1 wiring as well as give you a few other links to other sites with even more information on the swap.
Good luck and make sure to post when you start your swap. REMEMBER PICS ARE GREAT.
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 1992 camaro
Axle/Gears: 3:73
Re: Question about LT1 Swap Wiring
Mabey this one will clear it up a little http://www.camaroz28.com/forums/showthread.php?t=474185
And heres one for the lt1 wiring:http://shbox.com/1/harness_connector_faces.htm
1992 Trans Am
08-08-2015 08:16 PM
