3rd gen electronic dash connector
My 82 got a mechanical inst. cluster with a 70MPH speedo. I recently got a hold of this GTA electronic dash. It has be refurbushed and set to zero.
I dont have a the connectors or harness for it......
I was hoping the 4th gen connector would be the same......but they are not
Here is the one from a 3rd gen Firebird (bottom)....I am looking for the connectors that go into the two slots
I dont want to use a speedo box and use my stock one
What are my options here. Any suggestions advice is appriciated.
1 Post
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Re: 3rd gen electronic dash connector
It would be best if you also got the complete dash harness as well, which would probably involve you swapping out everything for the later model equipment (87+ headlight switch, heater controls) to make sure everything still worked, and you would also have to swap out the gauge bezel as well to an 85+
Car: '89 Trans Am GTA
Engine: WAS 350 - now L92 (alum. 378/6.2L)
Transmission: WAS 700R4, now a built T56
Axle/Gears: 3.27 9-bolt
Shoot - I haven't needed to take my dash apart, otherwise I'd do it in a heartbeat!
I'll keep an eye out at the junkyard though...
Car: 85&95 Trans am
Engine: 85-LT1 95-LT1
Transmission: 4l60e & 4l60e
Axle/Gears: 3.23 & 3.23
I'm just about to do this as well. My 85 has a cable speedo and since the lt1 swap I have a signal for the newer electric gauges. I bought the dash connectors off of a parts car to use as a reference. Got the 145mph speedo unit as well. I think it comes down to a matter of re-pinning the connectors that are already in the car.
Car: 85&95 Trans am
found this while searching
Wiring pinouts for 86-92 Firebird electronic dash cluster
upper connector
1 park brake
2 ground
3 dash lights
4 N/U
5 N/U
6 N/U
7 left turn
8 high beam
9 right turn
10 fuel gauge
11 (left spot beside voltage gauge)
12 (jumper to 12V from lower connector)
13 SES
14 shift
wire - upper
1 tan/white
2 black
3 grey
4 -
5 -
6 -
7 light blue
8 green
9 dark blue
10 pink
11 -
12 -
13 dark brown/white
14 tan/black
Lower connector
1 tach
2 ground
3 dash lights
4 choke
5 temp gauge
6 (left spot beside temp gauge)
7 N/U
8 oil gauge
9 12V switched power (key-on)
10 N/U
11 (right spot beside fuel gauge)
12 ground
13 seatbelt
14 speedo gauge
wire - lower
1 white
2 black
3 grey
4 grey (?)
5 dark green
6 dark green/white
7 -
8 tan
9 pink/black
10 -
11 -
12 black
13 yellow
14 light green/black
upper connector
1 park brake
2 ground
3 dash lights
4 N/U
5 N/U
6 N/U
7 left turn
8 high beam
9 right turn
10 fuel gauge
13 SES
14 shift
wire - upper
1 tan/white
2 black
3 grey
4 -
5 -
6 -
7 light blue
8 green
9 dark blue
10 pink
11 -
12 -
13 dark brown/white
14 tan/black
Lower connector
1 tach
2 ground
3 dash lights
4 choke
5 temp gauge
7 N/U
8 oil gauge
10 N/U
12 ground
13 seatbelt
14 speedo gauge
wire - lower
1 white
2 black
3 grey
4 grey (?)
5 dark green
6 dark green/white
7 -
8 tan
9 pink/black
10 -
11 -
12 black
13 yellow
rdog30,
Thats good info...... .......could u post up some pictures of the connector u got ... so I have some idea what I am hunting for ....
Thanks again !!
Thanks again !!
Car: 85&95 Trans am
You will not need to find another connector. Pull your gauges out. Re-pin your connectors to match the pin-outs from what I posted above. My car only had 1 grey wire for the dash lights so I spliced into that and ran another down to the other connector. You will need to add the wire for the speedo gauge. My car had 2 pink w/black wires(12v power). Plug one into upper 12 and the other into lower 9.
I am quoting this from another thread.
Do I need this box along for the electronic instrument cluster to work ? My car was orginally mech speedo so it didnt have it.
or will the LS1 PCM and the rewiring of my stock connector do the trick ?
Car: 1987 GTA
Transmission: 4L60e
You shouldn't need the buffer box unless you are running a later-model third-gen cruise off of it (like I am).
Car: 1985 Pontiac Trans Am
Engine: 6.6 Liter 406 c.i.
Transmission: T-56 6 Speed/ McLeod Street Twin
Axle/Gears: 3.42 9 Bolt Posi w/ girdle
I have a quick question that I haven't been able to find the answer to yet... I'm swapping an 87 cluster into my 85 Trans Am and getting the Dakota Digital Box to translate my T-56 VSS. The output wires from the digital box... would they go to Pin 14 and ground on the lower connector?? Unless I am reading that wrong... any help would be appreciated!!
Fast355
12-02-2016 06:33 PM
ambainb
04-25-2016 09:21 PM
eightsixseven
08-14-2015 03:09 PM
