LS1 oil pan swap question
Car: 88 IROC-Z , 00 CAMARO SS
Engine: BUILT 5.7 IN THE IROC, STOCK LS1 IN THE SS
Transmission: 700R4 , 4L60E
has anybody used a LH8 oil pan(hummer H3 5.3 oil pan) on their 3rd gen camaro ls1 swap? i know it hangs down alitle bit more then the ls1 pan but will it still work? Its still like 2.5 inches shorter than a 5.3 truck pan so i dont think it would hang too low. Looks like it leaves alittle bit more room for clearance issues not to mention its alittle cheaper as well. any help thanks
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Check this thread https://www.thirdgen.org/forums/ltx-...otor-into.html
I don't recall anyone discussing Hummer engines specifically.
Navy8125
08-21-2015 09:32 AM
