Tubular K-member, are they strong enough?
Car: 87 camaro, 98 Z-28
This looks like a good idea to free some weight and make the swap go easier in order to clear the A/C compressor but are they strong enough to support the car in daily driving or road racing applications? Looks like that one little tube going across wouldn't be enought to support the frame of the car. Does anyone on here have one? If so what is your opinion on it? This is for the LS1 conversion.
Car: 89 IROC/05 RX8
Engine: LS1/LS1
Transmission: T56/T56
Axle/Gears: 3.42 GM/3.55 8.8
Re: Tubular K-member, are they strong enough?
They are definately plenty strong for street driving (Im refering to the spohn one right now) as long as you have the front triangle supports.
just bought one appears to be an xcellent piece well made i havent used it yet but id say should be no prob rake the factory " hydroformed piece and wonder how it does it!!
Car: 91 Red Z28 G92 Spohn Suspn
Engine: 6.0/L92 Supercharged. Fully Built.
Transmission: 6L90E + G8 Shifter
Axle/Gears: 3.08
Car: 92 25th anv z28
Engine: 346 TC78 Turbo
Transmission: 4L80E
Axle/Gears: 3.25 9"Nodular, Strange axles
I've got mild steel. Bin driving the car for a month now. Been beating it pretty good (hard turns 35 mph+ fast runs 110mph+) no proplems yet. Infact the alignment is pretty close too. They must have a good jig. Also you save sooo much room. Do it!
92rsvortec350
19
10-09-2015 09:39 AM
