lt1 pcm tuning question
im getting ready to send my pcm off to get reprogrammed and i am not going to be running a/c,4l60e,vats or any of the emissions ,i will be running a 700r4,my question is what all should i have disabled /removed while im at it?and does the lt1 have a speed governor/rev limiter?if so should i have that modified to?,any help would be appreciated,thanks,joe
Re: lt1 pcm tuning question
a/c codes, vats, air, ccp can be disabled. The LT1 has a governor but its not activated by the factory. It has a rev limiter and I think even individual rev limiters depending on what gear you are in if you have a 4l60E. Madtuner.com should be able to help you out.
NBrehm
08-25-2015 11:49 PM
