who has the easiest to install aftermarket lt1 wiring harness?
ive been racking my brain tryin to figure out how to wire an lt1 into my car and no one seems to want to help me,so i think im just gonna get an aftermarket harness,can somebody at least tell me who has the easiest to install aftermarket wiring harness for the lt1 swap into our 3rd gens?and where could i get the vats and emissions takin care of?can a dealership flash my pcm?any help would really be appreciated,thanks in advance,joe
Car: 1992 camaro
Axle/Gears: 3:73
Re: who has the easiest to install aftermarket lt1 wiring harness?
You do here this is as easy as I could find , now you are going to make other connections but it will START.
http://www.camaroz28.com/forums/showthread.php?t=474185
http://shbox.com/page/index.html
With those 2 you should bu abel to get all you will need.
Car: 82 Trans Am
Engine: LTX
Axle/Gears: 3.42 strengthed 7.5 inch
My wiring harness was from speartech.com very good quality. I am sure others will chime in with other options..
Also, painless performance has a deal now where if you get their computer harness they will flash your computer for free. Check out their website.
1992 Trans Am
08-08-2015 08:16 PM
