LS1/LQ4 Motor Mount ?
Car: 1989 Camaro Iroc-Z
Engine: 305 TPI (LB9)
Axle/Gears: 2.77 posi
Would LS1 motor mounts (the part that bolts to the block, [clamshell...?]) work fine on an LQ4 (6.0L iron block)? Would there be any problems with the greater weight of the iron block? Just wanting to verify before I go spending more money...
Here's a pic of the LS1 mounts I'm thinking of getting...
Car: '89 Trans Am GTA
Engine: WAS 350 - now L92 (alum. 378/6.2L)
Transmission: WAS 700R4, now a built T56
Axle/Gears: 3.27 9-bolt
Re: LS1/LQ4 Motor Mount ?
No, there shouldn't be any difference, I'm pretty sure they should work fine.
ambainb
04-25-2016 09:21 PM
NBrehm
08-05-2015 07:57 PM
