LQ4 Thirdgen here I come.
Well guys I just got off the phone with the junkyard and I secured a 01 LQ4. I pick it up Friday. It will be getting a set of L92 heads and a cam from Synergy Motorsports. I can't wait to start the swap. I'll keep this thread updated with pics and info on the swap.
Car: '89 Trans Am GTA
Engine: WAS 350 - now L92 (alum. 378/6.2L)
Transmission: WAS 700R4, now a built T56
Axle/Gears: 3.27 9-bolt
Re: LQ4 Thirdgen here I come.
Well, so far I haven't heard of anyone who's done this swap who's been unhappy with it. Can't wait to get MINE going!!
Well, if it uses the same bolts as my L92 (& I can't imagine that it wouldn't), you'll want to get 3/8" x 16. I bought them in the 2-1/2" length, & they look like they're going to work just fine (going to borrow my buddy's cherry picker in the morning, & then I'll know for sure).
FWIW, your timing is really good, I just bought them earlier today...
Car: 1991 rs, 1992 z/28
Engine: 363 ci chevy sb
Transmission: 700-r4
no, the 3/8 fit, but are not the right ones. they can pull threads out if they are tightened enough. the correct bolts are 10X1.5 metric.
The engine is already on the engine stand using the 10X1.5mm bolts. Thank you though. The engine would be in by now but I still don't have a job so money is tight.
Terrell351
06-13-2021 01:13 PM
