swapping a tpi with an LS7
i am currently working on swapping an ls7 engine into a 91 rs model, i have searched the forums and have found a lot of helpful tips, anything i should know other then what i've already found about mounts transmission rear drive axle etc...etc?
Car: 92 25th anv z28
Engine: 346 TC78 Turbo
Transmission: 4L80E
Axle/Gears: 3.25 9"Nodular, Strange axles
Re: swapping a tpi with an LS7
Well if your swapping a ls7 in a thirdgen...Please post pics. All i can think of is you may have problems with the drysump/crossmember.
1 Post
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Where did you get an LS7????
Car: '89 Trans Am GTA
Engine: WAS 350 - now L92 (alum. 378/6.2L)
Transmission: WAS 700R4, now a built T56
Axle/Gears: 3.27 9-bolt
You have an LS7? You officially SUCK. Bastage!
Just kidding, that oughta be a pretty kick-a$$ project, good luck with it...
Car: 1986 WS6 TransAm
Engine: THREEFIDDY!
Alot of people can come across LS7's and LS6's with luck.. A friend of mine totaled his vette with a LS7 in it, and the insurance company sold it to the scrap yard for 2 grand and my neighbor got ahold of the complete engine for $500. I was pissed i didnt have the cash heh.
Can you make the LS7 non-dry sump?? I thought I remembered reading that you could somewhere... Either way....I would sell my firstborn for a low mileage LS7 right now. I dont have a firstborn...but if I did... haha.
I want to see pictures!!!! Post up some motor pics and some car pics...and MOST DEFINIETLY in progress pics. Will be a bad car when you get it finished....
J.
J.
Car: 1991 Trans Am
J.
J.
There are a LOT of other things that need to be done as well. Unless you want to run the throttle by wire setup (no throttle cable), then you also need to make sure the crank you get is for a 52x (I think) crank signal like the ls1 harness uses. Then you have to buy a new throttle body and some conversion parts to make the throttle cable work. After all that you either need new injectors and fuel rails or some conversion harnesses to work with the ls7 injectors and the ls1 wiring harness injector harnesses.
Like I said, its a TON of work to do.
Car: 91 RS
Engine: 383 Stroker 450HP
Transmission: TH350 3500 Stall no OD
Axle/Gears: 30 Spline Axles 4:10 gears
an ls7 in a 3rd gen would certainly be unique thats for sure.
1 Post
Car: 1991 Camaro Z28
Engine: 2002 SS LS1
Transmission: 6 speed
Axle/Gears: Auburn 3.42
You can find allot of great info on the following links, Tiberio Performance put an LS7 in a GTO
http://www.tiberioperformance.com/
They have a really cool ride along video on there, and here is one on fquick.
http://www.fquick.com/videos/LS7_GTO/903
Car: 1987 Chevrolet Camaro
Engine: 305 ci LG4
Transmission: TH-700R4
Axle/Gears: 2.73 non-Posi
Yeah, I would keep the dry sump system too, unless you run into real clearance issues, but who knows i have yet to see someone document the swap into a thirdgen. Dude, pics would be awesome!!
Car: 92 Camaro RS 25th Ann.
count me in on those pics too! Zo6's are rare in the yards here, so as soon as one comes in, they're pretty much already sold. so i guess for me i either have to fork over the $17,495 from Classic Industies, or steal a new vette. as for electrical and injectors, etc, etc...why not use the full harness and comp from the donor vette?
Car: 82 Trans Am
Engine: LTX
Axle/Gears: 3.42 strengthed 7.5 inch
Been 5 months since we heard anything on this.. I file it under UFO's and sightings of sasquatch..
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
yeah, did you really think someone had a spare LS7 laying around? The only places that do are race shops and race shops don't go to forums for help... atleat they shouldn't...
Transmission: 4L80E
Yea..When I saw the post I was calling Bull $hit.
Not nearly as cool as the straight ten I am putting in my third gen...
It was just laying around down by the docs so I picked one up...
I even got my friends to help drop in a new forged crank...
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
I don't see the point of this continuing. If the originator wants to fill us in on his progress, he can do so in a new thread.
Sanjay
08-12-2015 03:41 PM
