trans x-member with s&p motor plates
Car: 1987 Camaro Z28
Engine: 5.3L
Axle/Gears: 3.42LSD
What did you guys to for a trans crossmember if you used s&p plates on your old style v8 mounts? Pics please.
Thanks,
Eric
Thanks,
Eric
Engine: 5.3L
Axle/Gears: 3.42LSD
Re: trans x-member with s&p motor plates
You mean to tell me noone on this website is using the s&p mounts?
Car: 87 Formula
Engine: '00 LM7
Transmission: 4L60e
Axle/Gears: 3.23 posi
actually i've never heard of em lol!
maybe give Spohn a call and see if they know anything about using their 4l60e swap crossmember with the mount plates. If they mount roughly within a quarter inch of their mount plates, it'll probably work out just fine.
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
cam- mentioned them in a thread about Trans-Dapt plates.
They should put the engine in the same place as other swap mounts, so the trans crossmember shouldn't be an issue.
A lot of unknowns in that statement, but I can't imagine any swap adapter putting things in a place such that the trans crossmember would become a problem.
There I go again. . .
(I got the Trans-Dapt plates, but haven't done any trial fitting yet - still waiting on my Skulte T56 crossmember, anyway.)
Engine: 5.3L
Axle/Gears: 3.42LSD
I would still like to see pictures if someone has any. I would hate to buy a x-member and can't use it or have to modify it...
Engine: 5.3L
Axle/Gears: 3.42LSD
how people did their crossmembers on their cars with s&p mounts.
1992 Trans Am
05-10-2023 07:19 PM
mhatfield 14
10-24-2015 07:48 AM
eightsixseven
08-14-2015 03:09 PM
