LS1/T56 build thread
Car: 1991 Camaro RS
Axle/Gears: Tru-Track posi/Moser axles/4.10
Hey guys,
I completed my LS1/T56 swap at the beginning of September and figured its about time to get a thread going with the buildup.
I bought my motor and tranny from http://www.fpartssalvage.com/. They are located in Bristol, Pennsylvania. They were very accommodating and helped out a lot. Everything came to 4500 dollars from them. The motor was a 2000 Camaro SS motor with 40k miles on it. The transmission was a T56 (the 6 speed manual transmission). They also gave me the ECU, wiring, pedals, driveshaft etc with this. Everything was there to make the swap possible.
This is what I got:
Then the parts started coming in.
O2 sensor simulator
This is what I got:
O2 sensor simulator
Last edited by kubus_stroinski; 10-18-2007 at 05:10 PM. Reason: Automerged Doublepost
Car: 1991 Camaro RS
Re: LS1/T56 build thread
Motor mounts, tranny mount, fuel pressure regulator, VATS bypass module
Car: 1991 Camaro RS
3 inch electronic exhaust cutout from QTP
Car: 1991 Camaro RS
The teardown and some shots of the shop and test fitting
Car: 1991 Camaro RS
Cleaned and painted the engine bay. Also hung pedals and cut a hole for the shifter.
Car: 1991 Camaro RS
Some more shots of the engine bay painted and back inside the shop. Here we ran into some trouble since the AC compressor was hitting the steering. In the end we realized that we needed to shim the motor mounts up and it fixed our problem.
Car: 1991 Camaro RS
An under shot and my uncle and I machining some flanges for my exhaust
Car: 1991 Camaro RS
First night it was done
Some under the hood shots
I think this is all I currently have of this. In total it took 10 days to do everything. 68 actual work hours. Im so incredibly happy with the way everything turned out. If you guys have questions I will do my best to answer them. Cheers
Kubus
Kubus
Car: 1989 Camaro RS
Axle/Gears: 3.23 posi
[QUOTE=kubus_stroinski;3502323]My intake
Where did you get the parts for the intake and do you have part #'s?
Car: 1989 Pontiac GTA
Engine: 350 5.7 T.P.I.
Transmission: TH 700-R4
I was wondering if you could make a parts log for your build. Just name the parts you had to buy to do the swap and where. Thanks
Car: 1991 Camaro RS
Car: 1991 Camaro RS
Car: 2015 Chevy SS
Engine: LS3
Transmission: 6L80E
Hey man looks great. I was actually checking the F Parts eBay store before I read your post. There were some (what look to be) great deals on there but I wanted to get some feedback before a went ahead and dropped a few thousand on a new motor/trans. Looks like it work out real well for you!
A couple of questions:
How is the ride with the extra weight on those CM springs you are running?
1. My car bottoms out ALL the time with them I wanted to know if the LS1 makes any difference (if it gets worse).
2. Did you switch your rear end or are you still running the old "one wheel peel"?
3. Same fuel pump?
Thanks!
Chris
3. Same fuel pump?
Thanks!
Chris
Car: 1991 Camaro RS
3. Same fuel pump?
Thanks!
Chris
3. Same fuel pump?
Thanks!
Chris
2. The rear end is still stock. I'll change it when it breaks. Right now its fine
3. Same fuel pump
Car: Pair of 92 Z28s
Cool, always like build threads. Hopefully ill put one up when my swap is done. Bet your loving that LS1/T56 combo...Something tells me i should have saved 2 more grand and just bought an LS motor...but thats alright i can always get one down the road i doubt this will be my first/last engine swap lol.
I like how you used the engine hoist from the side of the car...not sure why i didnt think of that. Of course i pulled the engine/tranny together it would have been too hard to slide it back but for just the engine thats a good idea because i had to remove my front bumper and air dam.
Thanks for sharing some pics always gives me more motivation.
My only suggestion would have been to keep the engine bay body color.
Car: 1991 Camaro RS
Re: fuel pump. My fuel pump is holding up just fine thank you
Car: 1987 Z28
Engine: 2005 5.3L, LS6 Cam
Axle/Gears: DTS 9" 3.50 TrueTrac
NICEEEEE, Hey man we should meet up sometime I live in windsor and travel up to london for fun sometimes! I would love to check it out in person!
If ya got msn add me at jamesrichard727 @ hotmail.com
Car: Camaro
Engine: 6.2L
Nice swap. Mighty fast build time there.
I agree with others about that fuel pump your not the first to try and run a stocker you might wanna look into what happened to other guys who did ( MrDude1 for starters ) it wasn't a good result.
Car: 1991 Camaro RS
Sorry to offend you. But, it looked like you had some quality parts, and I was interested what they were. Anytime is fine, don't get in a rush, I'm just interested.Dude. But, it does look like you have a nice addition to a nice car.
I hate you!!! I wish mine would be over in 10 days, its been more than 10 months!! Granted, it's on and off, but still....
Where did you end up putting the computer?? Punch a hole in the fire wall or what??
BTW, looks like a great install, and I love your car collection there. An I30 (or I35?), a CRX and a Porsche 914, that's vareity!
Car: 1991 Camaro RS
Most of those cars arent mine. Only the I35 and the Camaro. The others were the dude's that owned the shop we were working at.
Car: '91 Camaro RS
Engine: 3.1L
Hah. I know exactly where that clown thing is, and they never move it...it just sits there and rusts...it's about a 10 minute drive from my house...small world.
Car: 1991 Camaro RS
We lived in Laureldale and did the work in Fleetwood. This thing was really funny looking
Car: 1991 Camaro RS
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
Hey! I sent you a PM on Z28.com concerning the wiring. Did you do the wiring yourself?
Car: 1991 Camaro RS
Car: 1991 Camaro RS
Just bumping this thread lol
My stock fuel pump died eventually just like you guys said it would
I now have a proper Walbro in there and the car works really well
Car: 1991 Camaro RS
Update to my car.
Stock V6 rear end decided it wanted to hate life so I replaced it with a fourth gen rear end with 3.42s. That promptly blew up the first day I had it in so I decided to do something more proper and got in touch with cam- about something that I can beat on and not worry about it exploding all over the road. I finally had it delivered Saturday afternoon and Mike helped us get it in. Thanks a lot for all of your help dude.
Here are pics of the install process (and my new brakes too)
#45
NICE Glad to see you are still tinkering with her. Nice to know you have some beef out back so you dont have to worry.
Im running the 4th gen alum driveshaft...which worries me a bit. But there are guys with a lot more power than me with an alum shaft....so Ill wait til she blows. haha.
Good work!
J.
Good work!
J.
#46
Car: Camaro
Engine: 6.2L
Damn those are some sweet rotors. Yeah man no worries it was fun anyways although I had the bobble head going pretty good by the time I got home LOL. Is the cam going in this week?
#47
Car: 1991 Camaro RS
Cam *should* be going in this week. All the parts are ordered so we're just waiting on that. Hopefully its in before track day. Am I allowed to beat on the car just after a fresh cam install?
#48
Car: Camaro
Engine: 6.2L
Yeah with roller cams there is no break in so your good to go right out the gate. Ideally its nice to put one heat cycle and cool down through the valve springs before max RPM but your not going to have to worry about that because when they tune it they'll wring the snot out of it and make sure everything is good to go. I'm quite curious to see what she MPH's with the new cam through manifolds so I hope they get it done this week
#49
Car: 1991 Camaro RS
Took the Camaro to the track today (second time ever at the track) and ran a 13.96@108.46. Im pretty excited
