LS1/T56 build thread
#52
Car: 1991 Camaro RS
Axle/Gears: Tru-Track posi/Moser axles/4.10
Re: LS1/T56 build thread
Well my car broke down Sunday night. I was driving through Michigan and my volt gage was being stupid. Then eventually it stopped charging and died on me in the middle of nowhere. I got it towed and repaired in Marshall Michigan so now it works again. But what a shitty deal.
Anyways, it goes for new cam tomorrow.
#53
Car: Camaro
Engine: 6.2L
How did yours go?
P.S. your so gonna dig that cam man
#54
Car: 1991 Camaro RS
I usually keep an eye on my gauges every once in a while when Im driving. My speedo isnt hooked up so thats not why I look down. Speed is displayed on the GPS.
Anyways, I looked down and saw that the gauge was at like 10 volts and I found that pretty odd. But I kept looking at it and after like 30 seconds or so the gauge went back to normal charged level. So I figured I was safe and wouldnt have to worry and could make it back to Chicago and swap an alternator at home.
I kept an eye on it though and it would continue happening more frequently. It would drop to like 12 volts and then keep going down as the battery was draining and then eventually pop back up again for a few minutes and be fine.
Eventually, it stopped popping back up again and my gauges stopped working etc so I pulled off the interstate and called AAA to tow me.
The towed me to Marshall MI to a certified AAA shop which was super good to me. I had to stay overnight at the Comfort Inn accross the street. They ordered the new alternator for me from Grand Rapids and put it in. While I was waiting, they gave me their shop car (a Chrysler Pacifica) so I could bum around town a bit and not be bored.
What a correct shop. Ive never received that sort of hospitality anywhere else.
So yeah, thats the story.
The cam will be super awesome. I cant wait.
#55
Car: 1991 Camaro RS
The Camaro is at the shop getting the cam done. I should be getting her back tomorrow evening. Im looking forward to it so much.
#56
Car: 2012 Corvette
Engine: LS3
Transmission: TR6060
My alternator caused a similar situation with my car, I'm not sure if the voltage gauge was acting up or not. I thought the battery was going bad because it was almost 5 years old. I was just driving and I took a turn and my car stalled and wouldn't start back up because the battery was damn near dead (it could hardly run the lights).
#57
Car: 1991 Camaro RS
You're not doing it yourself?
#58
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
Hey guys... A word of wisdom...if you can call anything rattling around in my head wisdom...
If you are using the LS1 set up, and the alternator uses that one little wire, you might have issues with that plug. My volt meter was doing the exact same thing. Next couple of days, acted strange, until one day, I noticed it wasnt charging. I replaced the alt, all seemed well.
Couple days after that, same issue. So I wiggled the wire in that plug, and it started charging again. Im guessing when I replaced the alt, it disturbed the wire enough to make contact again.
What I learned was, that wire is VERY fragile. If there are just one or two strands busted, there are only a few strands left making connection. I took the plug apart, resoldered wire in there, and about a week or so later, it broke again.
Fed up, I went to GM, and ordered a new pig tail for the alt. It comes with the plug, and wires coming from each of the pins. I removed all the pins except for the one I needed, and soldered it as far up the original wire as possible. The reason I removed the pins instead of cutting, is now I have spares.
But...the wires that come with the plug are much heavier in gauge than the original harness. So its been good since and I suspect it will last for awhile.
Just my experience with the sudden voltage seizure blues.
J.
EDIT:... Did you mention what cam you are going with kubis?? I may have missed it.
J.
#59
Car: 1991 Camaro RS
Sorry Justin. I didnt see your edit earlier.
Cam is 228/232 .595/.605 112+1 LSA
Anways, I called the shop and asked them for an update. The owner told me that he is finishing up the install now. He needs to get my spark plugs back in, valve covers on and onto the dyno. He says he could roll it out tonight but he's not sure if he will have it tuned properly if he rushes. I appreciate that attitude. I will have the car tomorrow evening for sure. So looking forward to this!
#62
Car: 1991 Camaro RS
Well its a Mustang Dyno so its going to be a lower reading anyway. 370 wheel horse on a Mustang Dyno would be pretty sweet.
#63
Car: 1991 Camaro RS
Uh oh. I just spoke to the tuner... He's saying its not reading as high as he was hoping it would... But I dont actually know numbers. I guess I'll have to wait an see a bit later.
#64
Car: 1991 Camaro RS
Some pics from the evening
And exhaust clips
Idle through muffler and then slow rev to 3000 and then quick rev
http://www.youtube.com/watch?v=uVngfkl8Aog
Same thing but through the cutout
http://www.youtube.com/watch?v=RbbQIN_FwZU
And exhaust clips
#65
Car: 86 Trans AM
Wow man... That thing sounds great! Sounds meaner than mine!!! Much better than the last time I heard it.
How'd the numbers turn out??
J.
J.
#66
Car: 1991 Camaro RS
340 at the wheels on a Mustang Dyno. The dude showed me all of the graphs and junk and said my manifolds and ypipe are hurting my numbers but I should be at 400 with longtubes. So that will be my next mod lol
#68
Car: Camaro
Engine: 6.2L
340 at the wheels is not bad at all and more than enough to run 12's with ease. Get your 60' down and you'll cake walk into mid-low 12's
#69
Car: 1991 Camaro RS
Im hoping thats possible. Sort of depressed that the numbers arent a bit better but I guess it should have been expected with stock manifolds
#70
Car: 86 Trans AM
Numbers are numbers....How does she FEEL? Thats whats important. Ive seen some low dyno number cars romp on some higher number cars.
340 isnt terrible. Like Cam said, maybe tweak the suspension alittle bit, some decent rear tires and you'll be able to hook and make better use of that 340 hp, than some guys can make use of 600...
Plus...it sounds bad now! Looks great, sounds great...drive the crap out of her, and keep modding until you are where you want to be.
J.
J.
#71
Car: Camaro
Engine: 6.2L
Yeah I understand I missed my goal number by about 35hp and at first I was bummed until I drove it yahoo!! The track numbers beat my power level expectations compared to my dyno results and then I started reading all these posts about ignore dyno #'s over at tech etc. I saw one guy over there cam only at 345 rwhp blasting off mid 11's and I've seen many guys over there bragging about 420 rwhp and then running mid 12's so who knows. LT's will pick up your power levels big time though now that your cammed the manifolds are definitely holding you back but that'll give you something new to shoot for. I'm still undecided on whether my next build will be more cubes or boost... probably more cubes I just love that N/A stuff
#72
Car: '89 Trans Am GTA
Engine: WAS 350 - now L92 (alum. 378/6.2L)
Transmission: WAS 700R4, now a built T56
Axle/Gears: 3.27 9-bolt
Yeah, the "logs" are definitely holding you back, I'd say that once you get the long-tubes, there's a very good chance you'll be somewhere around 410... Rather than a hp number, I'm hoping to be able to run somewhere in the 12.6 to 12.99 range with my new engine. Considering the 5800 to (sometimes) 7000+ foot DA at my home track, I think that that would roughly equate to 11s at sea level...
(Ahhh, who am I kidding? I'm hoping for around [the sea-level equivalent of] 440 hp with the long-tubes, etc.)
BTW, your car sounds DARN good, thanks for including the versions with & without the cutout open - I got a DMH e-cutout last year, but sold my original engine before I got it installed. Now I have a pretty good idea of the difference to expect... Much appreciated.
#73
Car: 1992 GTA
Axle/Gears: 4.10
Yep, if you have the option get longtubes and some 4.10's.
Once the car is tuned and the exhaust flow is less restrictive you will notice the cam will be peaky with stock gears.
I added 4.10's and it changes the manners of the car entirely. My first two gears shred the M/T Sportsman SR's even rolling slowly into WOT. Car is much more responsive daily driving. I have a full bolt on/cam ls1 and thus far the 4.10s were the best bang for the buck.
#74
Car: 1991 Camaro RS
#76
Car: 1991 Camaro RS
18 inch wheels. 8.5 and 10.5 widths respectively. 40 series tires. 2 inch adapters at the front. Nothing on the rear because I have a fourth gen width rear end.
#78
Car: 1991 Camaro RS
86CamaroDan
09-29-2015 10:08 PM
UltRoadWarrior9
09-02-2015 08:24 PM
