411, c207, aldl, vats questions
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
I'm installing the 411 ecm/pcm into my car, few questions.
On the c207 port, there are 4-5 power wires, a wire to the ses light, vats wire, and a few wires to the obd1 aldl port. I got this. I tap the 411 ses light in here. I'm creating new ecm/pcm power points under the hood.
I am wanting to wire my OBD2 port over on my passenger side and leave my factory dash harness untouched. I can use one of the power points from c207 for IIRC pin16. Then from here I'm unsure what to do. Do I ground pins 4 and 5? Then take what pin(s) on the ecm, to what pin(s) on the OBD2 port? I'm at work right now so some of this I'm going off memory.
Has anyone sucssfully installed 4thgen vats into a 3rd gen? And now, I dont want to just "disable" it like I keep reading everyone say on here in my searches. My car is a vert and sometimes doesnt get parked in the best areas. And yes, this winter its getting an alarm.
Any help please.
Any help please.
![thank you](https://www.thirdgen.org/forums/images/smilies/thanks.gif)
Re: 411, c207, aldl, vats questions
Oh man, I must have been sidetracked when I posted that, sorry man, here's the link.
https://www.thirdgen.org/forums/ltx-...questions.html
Engine: 350 S-TPI
Thanks. I gave him a pm as well, glad I did because now I have a few more questions for him.
