L99 and LT1 questions
Car: 89 RS
Engine: 305 TBI
I need to know if the intake, fuel rail, wiring harness, sensors, and throttle body was the same from an L99 to an LT1. I tried a search but got confusing answers. (I want to swap those parts from an L99 to an LT1 that doesnt have them.)
Thanks,
Andrew
Thanks,
Andrew
Car: 1992 camaro
Axle/Gears: 3:73
Re: L99 and LT1 questions
Thw L99 is V-6 IIRC the intake,fulerail<-- NO.I dont know the size of the tb but I would bet no. Some sensors mabey,wiring???? dono about that one.
Car: 1990 Formula
Engine: 95 LT1
Axle/Gears: Weak 7.5 with 4.10s
I believe the knock sensor might be different. The rest should be the same. I know the intake and rails will swap right over.
Car: 91z,97ws6,98fb,87&90jeep,05 yz250
Engine: 5.0tpi,5.7LT4,5.7LS1,4.2I6,5.7TPI,1
Transmission: t5,4l60e,
keep in mind the smaller displacement will have smaller injectors and probably a smaller tb. but thats no big deal to change
