Coolant in the oil...Blown head gasket?
Car: 1991 Z28 Vert
Engine: LT1 350
Transmission: T56 6 Speed
Axle/Gears: 3.42 LSD
Today,
When I checked the oil, I noticed it was a little high on the dipstick. So I decided to change the oil just because I haven't changed it since the last time I tried to remove the oil cooler. Anyway, when I unscrewed the oil plug the oil came out milky and very watery. I am pretty sure that I might have a blown head gasket I just wanted to see if you guys agree. How involved is changing a head gasket besides removing the intake and heads?
Thanks in advance,
Jay
Thanks in advance,
Jay
Car: 87 TA
Re: Coolant in the oil...Blown head gasket?
Remember that you have to take the distributor out too. you'll have to set your timing once it's all abck together. Put a mark on your dist. cap and on the firewall to mark the current location. it'll help when setting it later.
1 Post
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
LT1's don't have standard distributors. They are in the front of the engine.
Best thing also, pull the headers off and take them out as well, makes for easier removal. Also you may want to go ahead and get new headbolts since some of the LT1's have stretch bolts, but I believe that started in '96. I changed mine to be on the safe side. You'll also have to pull the accessory bracket as well.
A blown head gasket could also make the car run the way it's been running, might have just found the main reason....although a sucky reason.
Car: 1991 Z28 Vert
Engine: LT1 350
Jay
Car: 87 TA
Ya know, I completly forgot about that. lol. sorry. I just got done rebuilding a 305, 350, and a 400...I had distributor on my brain.
Car: 1991 Z28 Vert
Engine: LT1 350
Okay, I changed the gaskets and I have everything back together. Now I just need to know one thing. How do I adjust the valve lash? Should I tighten the adjustment nut down initially or should I leave them loose before starting it?
I plan on doing the valve lash adjustment with the engine running?
Thanks,
Jay
Thanks,
Jay
Car: 1991 Z28 Vert
Engine: LT1 350
Went out today tried to fix the intake leak. Upon removal I noticed that the oil looked alittle watery. Check the dipstick and the same thing.
Question:
After changing a head gasket did you notice that the oil was still alittle watery. Maybe from the residual coolant that was still in the cylinders. Could somebody help me out with this before I take the passenger cylinder head back off.
Thanks in Advance,
Jay
Question:
Thanks in Advance,
Jay
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
so, new head gaskets and more water?? did you change both?? how much water?? same as before you changed the gasket??
i would change the oil again and see how much water got back in, if any.. could be the left over water.. you can only hope it was the left overs..
if its not just the left overs, do i dare think a cracked block??
Car: 1991 Z28 Vert
Engine: LT1 350
5678TA,
Yes, new head gaskets and more water. I changed both and I checked the heads for warping. When I drained the oil I did not find as much water in the oil as last time. So I'm hoping that it was just some left over fluid. Anyway, do you think I should put some motor flush in when I change the oil? Just so it can circulate and clean all the stuff out.
I don't even want to think about a cracked block.
Thanks,
Jay
Thanks,
Jay
Car: 1984 Trans Am
you can flush it if you want.. if you really think its still leaking, put a leak sealer in the water system.. most sealers require that ALL the anti-freeze be out of the system.. i leaked a bit once and i ran that stuff in my motor at one time.. now i run straight water in my motor.. no anti-freeze/water mix..
3rd gen money
09-08-2015 11:40 PM
355tpipickup
08-27-2015 08:13 AM
NinjaNife
08-23-2015 11:49 AM
