94 Impala SS lt1 what Headers??
Car: 00 ss 89 iroc lt1
Engine: ls1, lt1
Transmission: M6, auto
I am going to be swapping a 94 LT1 into my iroc and i was wondering what headers are the best? This motor does not have D port heads according to the mechanic who is helping me. Otherwise i would just use the headmans on the other threads.
1 Post
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
All of the LT1 engines had d-port exhaust ports. The Hedmans will work just fine. Only difference between the Impala motors and F-body ones are the cast heads instead of aluminum.
Engine: ls1, lt1
You wouldnt happen to have a better pic of the exhaust port for me to show him maybe they are d ports and they just dont look like ds to him
THanks
THanks
1 Post
Car: 1987 GTA
That's the only pic I could find, and it was off of e-bay. You can tell they are d-ports with the bottom of the ports being flat, and the top curving around.
1 Post
Car: 1987 GTA
They should, I know that Trick Flows do and I believe that AFRs do as well since they are for an LT1 and all LT1 engines had d-port exhaust.
jerflash
09-24-2015 03:11 PM
mygta87
09-14-2015 10:36 PM
