88 Iroc 364 carbed LS2 swap
Car: 2001 Camaro SS
will a TKO 500 or TKO 600 bolt right up to a 364 LS2 motor.
and will a cross brace from Hawks work with this type of transmission? my cousin wants a 5 speed, not a 6speed!
Car: IROC-Z
Engine: LSx
Axle/Gears: Fabbed 9"
It should bolt cause its the same bolt pattern as a standard sbc. The problem lies in the tranny imput shaft. Its not long enough or something... I believe some company made adapters to make it longer.
There was a thread on ls1tech.com this week about it. You should take a look at it.
As for the crossmember, you should call Hawk directly.
Car: Camaro
Engine: 6.2L
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
tko is pretty stout 5 speed. prolly stronger than a t56.
you can get a small block bellhousing, and mcleod has an adapter for the crank hub and also an adjustable hydraulic throwout bearing.
Car: Chevy Camaro Iroc-Z
Engine: LS2 6.0L
Transmission: T56 Six Speed
Re: 88 Iroc 364 carbed LS2 swap
Hey, Im getting ready to do a ls2 swap in a 86 iroc. What oil pan did you use.
mustangman65_79
08-11-2015 03:17 PM
