cc306 cam issues
Old 11-06-2006, 06:19 AM
ssean92's Avatar
Car: sold
cc306 cam issues
is there anyone out there that has installed this cam and used madz28's tune and had no lowend power? this car just dont feel right and cant figure out what is the deal. i am running the cc306 with the 918 springs and 1.6 crane r/r. i installed the rockers like normal o lash then 1/2 turn. the heads are pretty much stock lwith slight bowl blend. can data log if that will help
Old 11-06-2006, 07:26 AM
ssean92's Avatar
Car: sold
well looking at my factory tune and my madz tune looks that the madz tune took out anywere from 2-4 degrees of timing from the factory tune . doese that seem right????????? that is through out the main spark and advanced spark range.
Old 11-07-2006, 09:44 AM
ssean92's Avatar
Car: sold
well after its all said and done it if fixed as of now. i changed one injector put the factory fuel pressure reg back on, re adjusted the valve lash, put conector grease on all the o2, opti, mass air connectors and it is running so much better. i plan on playing with the timeing table before i go to the dyno to see if i can get more out of it
not that anyone was conserned, thanks anyways,
Street Lethal
04-30-2019 12:14 PM
Fronzizzle
03-18-2019 08:29 PM
deracer
04-11-2016 12:04 AM
bamaboy0323
09-03-2015 06:07 AM
86White_T/A305
08-17-2015 12:16 AM
Quick Reply: cc306 cam issues
