What did you guys do for your temp sensors?
Old 10-12-2006 | 03:45 PM
dingle's Avatar
Car: '83 Camaro
Originally I had installed a temp sensor into the water pump and used that for my stock 83' gauge. Left the LS1 temp sensor installed next to cyclinder #1 and used that to control the fans and such (as you normally would on a LS1).
Well I have to replace the water pump and I'm curious how you guys did yours. I want to use an autometer gauge, but I am not sure if it will work off the PCM signal.
I don't really want to use the back head spot as it's to tight in there and would be a freaking pain to do.
Any input would be appreciated.
This is what I did.
Old 10-12-2006 | 11:30 PM
StevenK's Avatar
Car: 91 Z28
Axle/Gears: 3.73 Hawks 8.8
I took a stock sensor, ground it down, threaded it, and put it in the head...which is exactly what you said you don't want to do.
So...no help from me.
Old 10-13-2006 | 01:10 AM
RaverRacerX's Avatar
Car: 1989 Camaro RS
Engine: Ellis Juan
Transmission: t-56
the autometer guage should come with a sensor. just make sure u get the right adapter from equus
Old 10-13-2006 | 03:51 PM
dingle's Avatar
Car: '83 Camaro
Well if you guys use a non LS1 sensor, how are you telling the fans to kick on?
Cuz I can get an adapter for the temp sensor I showed in that pic to fit in the stock LS1 temp sensor hole. But then nothing would be wired to tell the fans when it is time to turn on.
Old 10-13-2006 | 11:39 PM
StevenK's Avatar
Car: 91 Z28
The stock sensor is still in the driver's side head hooked to the ECM, the thirdgen sensor is in the pass head connected to my stock gauge
Old 10-14-2006 | 02:39 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
there is another plug on the passenger side head in the rear.
i used it, and plugged the drivers side on mine.
one less eye sore of a wire to look at.
Old 10-15-2006 | 07:40 PM
dingle's Avatar
Car: '83 Camaro
Dayum, how was the fit back there it looks pretty tight to me.
Old 10-15-2006 | 08:13 PM
xgtharo86x's Avatar
Car: 86' Trans am
Engine: 85 LG4-non cc carb(building a 350)
Transmission: Rebuilt 700R4,vette servo,2200stall
Axle/Gears: 2.73 Posi
wrong thread
Old 10-15-2006 | 08:32 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
depends if you got an a/c box.
either way, underneath would be the best bet then.
Old 10-16-2006 | 09:15 AM
dingle's Avatar
Car: '83 Camaro
Yea the full A/C box is still on there.
Old 10-17-2006 | 02:39 PM
Smokin87TA's Avatar
Car: 1987 Trans am
Engine: Cammin Ls1
Transmission: Th400 w/brake 5500 stall
Axle/Gears: Moser 9" w/ 4.11's
I just picked up a one wire temp sender from autozone and put it in the back of the passengers side head. I used an adapter because i couldnt find the exact thread size in the sender. Just ran that wire to my stock guage and it works great. Hooked up a scan tool to verify that it was corect and it was.
Old 10-19-2006 | 03:34 AM
StevenK's Avatar
Car: 91 Z28
Dude, its not that tight....I still have my stock airbox, the ECM over there, sub wiring, etc....
I was able to get it threaded in with a minimum of coolant spillage. I was unable to find the adapter everyone is talking about so I just ground down the stock sensor and threaded it.
Old 10-19-2006 | 07:41 PM
Smokin87TA's Avatar
Car: 1987 Trans am
Engine: Cammin Ls1
StevenK that is also a good idea. I bought the sensor from autozone but it is made by autometer. i will try to find the part number of it but it was like $7 just for the adapter.
91REDZ28VERT
08-18-2015 11:16 PM
Street Lethal
08-14-2015 09:25 PM
92purpz28
08-11-2015 03:30 PM
squiggy2
08-09-2015 10:30 PM
