Why USE Fuel Pressure Regulator??
Car: 1992 Camaro RS
Transmission: T56/B&M/Ls7
If i'm putting a stock LS1 fuel pump in my tank, why do I need to run the Aeromotive Fuel Pressure Regulator With the stock LS1 swap??
Thanks,
25thredrs
Thanks,
25thredrs
Car: Take
Engine: Your
Transmission: Pick
If your running an LS1 F-body fuel pump, then all you need is a high pressure line to the rail. The fuel rail has a pulsation dampner and as you already know, the regulator is in the fuel pump. I have not done the LS1 pump swap, but I see what your getting at and I agree.
Car: 92 quasar gta
Engine: Nothing
Transmission: Nothing
Axle/Gears: 4.11s
i run the ls1 tank and the lines up to the fuel filter bolted into the 92's location.. well close enough when i modded the bracket and stuff
i then use the return like for the evap
Car: 1992 Camaro RS
If i'm using the stock 92 tank and just switching out my sending unit for the LS1 sending unit, would I even need to run a return line.....Do the LS1 fuel rails even have a location for a return line..b/c i couldn't find one...IF anyone has a picture that would be great.
Thanks,
25thredrs
Thanks,
25thredrs
9192camaro
16
02-03-2019 12:21 AM
