So i dropped my car off at ThirdGenResource Today.......
#156
Car: 1993 Toyota Supra
Engine: Inline 6
Transmission: 6 Speed
Axle/Gears: 3.13
I wonder why they didn't drop the front subframe like they did Jason's 91' Z28 for his ZZ4 Swap.
http://www.thirdgenresource.com/jasons91z28
#157
Car: GM & Jaguar
Engine: Various
Transmission: Various
Axle/Gears: Various
Now where was I..... ah yes, pooping my pants with glee & envy
#160
Originally posted by Dante93GTZ
How much for the labor for the swap?
It's not something that is cheap, I'll stress that right now.......I would suggest setting aside at least $10,000 for a nice clean swap with a few goodies also.......
#161
Car: Faster
Engine: Than
Transmission: You!
Have they set the motor in the engine bay yet?
If you want to run AC with your stock K-member, you are going to have to have them notch it for the LS-1's AC compressor.
#162
Car: 86 Iroc-Z28
Engine: FB385
I'm gonna guess atleast $2000 for labor if i added his parts list up right. Just a guess though! Any other takers for a guess?
#164
1 Post
Car: 92 Z28
Axle/Gears: 3.73 10 bolt
Originally posted by 87rediroc
Awesome! Looking good. By the way, is it better to bolt or weld in the new motor mounts?
#165
$1,875 for the labor is the estimate that i was given, but i'm not sure if that will be the final number i get when all is said and done.....so i don't want to throw out any numbers until i get everything finalized with the correct information
BTW that's labor for EVERYTHING...
Remove 305 TBI
Remove Transmission
Remove Rear End
Install LS1
Install T56
Install New Rear End
Install New fuel pump
Install all the other stuff as well (STB, SFC, Nitrous)
#166
Car: 86 Iroc-Z28
Engine: FB385
You forgot the exhaust work too! lol j/k man, thats not a bad price really. You figure if they spend a solid 40 hrs on the car and all of the work, it equates to about $50/hr, which tends to be the norm. I also figured in the price for the wheels. Did you buy them from them too or no?
#167
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
Originally posted by FLYNLOW92rs
Not any performence tuning......Getting rid of VATS, Un-necessary stuff
I feel much more comfortable with my '91 GTA and VATS...
#168
Car: 1992 Camaro RS AKA Big Nasty
Engine: Carbed '79 350 block, 360hp/380ftlbs (flywheel)
Transmission: 6speed from an unidentified 4th gen. ask me, ill tell you.
i want to see what no back seats looks like. Mine are coming out for summer time because i refuse to taxi people around in my maro, if i wanted to do that id buy a van
Taking out the back seats takes 5 min. Total of 4 bolts to undue.
#169
Car: 1990 Camaro
Engine: 355ci
Transmission: TKO-600 5 speed
#170
yeah its carpeted in the back.
i had the backs out of my 86 to avoid playing taxi..worked great til people figured out having no back seats gave em more headroom. dammit.
the buckets arent all that uncomfortable without the seats, you just have to watch out for this little 3-4" piece of round bar the seatbacks hook to.
thats the only thing aside from where the tops mount to the sides of the car that you can see.
-JT
-JT
#172
You must loose VATS to get the LS1, I don't know a single person who has done the swap and kept it.....
Everyone flips out over the price and tells me i paid WAY too much, but when you sit down and actually crunch the numbers, it comes out right, and in some cases i got some discounts...
#174
Originally posted by A88GTANotchback
all i say is that if ur cars gonnab e that damn sexy after all this REPLACE THE Discolored tanks.
That will probably make the engine bay look better then the LS1 will.....:lala:
Don't forget the failed attempt to spray paint the caps of those discolored tanks the same color as my car.......(Back in those Fast & Furious inspiried days......).....No idea what i was thinking....
#175
Car: 86 Iroc-Z28
Engine: FB385
It is pricey, but if you are not willing or able to do the work on something like this and you do not know anyone or are not in the "business", it will get expensive! That is what sucks, there is no set price on a lot of stuff like this, so people can put whatever price they want on "custom" work. Only thing the consumer needs to worry about in the end is, if they are happy, and if the work will hold up as well as the mechanic's word, and if they will back it 100%. So, any ETA when it will be done?
#176
The engine is already in the car, parts are on order or already arriving.....So i don't see it taking much longer then 3 weeks.....Oh yeah, the rear end still needs to be replaced.....
#179
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Unless they're stupid your VATS should still work to disable your starter relay, the vats just needs to be disabled in the LS1 computer which only controls the fuel injectors.
#180
...but the line has been drawn at the wing, it's staying
Wow, I'm so jealous of your car. I'd take it with the wing any day. I'd say the days of the thirdgen being "that rusted out ******-wearing-*******-driven 80's wannabe-sportscar" are numbered, with many thanks to FLYNLOW, tpiroc, crazyhawaiian, and a whole slew of others here.
YEEEEEEEEHAWW!!... uh, I mean NICE JOB!
#181
UPDATE:
Called Roy today......Getting a 4th Gen gas tank installed instead of the stock thirdgen one....
Not to much modification needed, but i have no idea on what exactly is involved, but i'll get pictures of it when i get the car back.......
#182
Car: 1990 Formula Firebird
Engine: 305TBI w/ Functional Sport Hood CAI
Axle/Gears: SLP Posi and 3.23 Gears
good ole roy, he really helped us out on my back seat.
#184
Originally posted by Kandied91z
what's the advantage to the 4thgen gas tank? is there something wrong with yours?
It's lighter and holds more gas too.....
#185
1 Post
Car: 92 Z28
hmmm...gas tank recall...? maybee I should check into that....
Good luck with your car man, its gonna kick ***. If you go through athens on your way home hit me up I'd love to check it out!
#186
1 Post
Car: 1987 Camaro Z28
Engine: 335 TPI Stroker
Transmission: Tremec TKO 500
Axle/Gears: 10 bolt / 3.42
Yep I beleive the 4th gen tank is a plastic-synthetic type material, probably a little lighter and won't rust
Can't wait to see what this thing looks like when it comes out
#187
where would you go to find info about the recall?
#188
BUT, you will find that dealerships won't honor it anymore because it's over 11 years old.......I believe there is a time frame in which they no longer have to honor a recall.......They didn't fix mine.....
#190
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
hmm. vats.
in 92 it was jsut a simple little pellet resistor on a key.
today its grown to.... uhh.... still the exact same simple little pellet resistor on a key....
they can make VATS work. they SHOULD make it work. its pretty damn effective.
#191
Car: Pair of 92 Z28s
very cool man...your car has grown on me too as i dont think it looks bad with the wing...though not a fan of the wheels(which your fixing that) and the side vents are alright. But thats not point here...your getting a LS1!! So cool and with the T56 and a new rearend..awesome job man cant wait to see all the pics when its done!
#192
Car: 2008.5 Mazdaspeed 3 GT
Engine: 2.3 DISI Turbo
Transmission: 6 speed MT
Very nice to see you're adding some go to the show and whoa! I keep going back and forth on whether or not to dump 10 grand on my car too. 10 grand is only a down payment on a new car, but it can make one hell of a 3rd gen!!!
#193
The LS1 tanks from 99+ got a partially rubber neck right by the tank, too. That'd be cool, but hopefully with the walbro I'll never have to drop it again.
Hope it all works out for you man
#194
I'm sure the motor is in by now, so anychance on you getting a pic or two of the motor in the engine bay?
He also said he would get back to me to see if VATS can be programmed back into my computer systems.......Waiting on a call from the people that are doing the harness....
No updates other then they are waiting on the harness to arrive.....
The SFC's and STB are probably both going on the car this week....
Only things left as of yesterday are STB, SFC, Wiring Harness, Nitrous, Vette Fuel Rail Covers, Air Intake(doing myself).......hopefully no more then 2 weeks......It's already been 5 weeks......
#196
Car: 1991 Z-28
Engine: TPI
Transmission: 5-speed Rear:3.73
your car is gonna be an animal...Im waiting for the pics of this conversion like it was new **** heres a pic to help while we wait for the car pics....
#197
Get ready to feel the wrath of non-third gen related picture police!!! Especially non-work safe pictures like that. Thanks for posting it though.
Do they have any more information available on the fuel tank swap? All I could find in the searches were people talking about doing it. Nobody ever reported finishing a tank swap that I could find...
#199
Car: 1989 Iroc z hardtop
Engine: peanut LB9
Transmission: slopomatic TH700R4
you need it because an LS1 has a return line for the fuel. where our tanks do not. BTw what exhaust is going on the lS1. ewhat headers.
because u have gotten me kinda jump to find an LS1 and T56.
before i buy a 383/afr/HSr and th700 for my car
cause i'm allready looking at close to 7grand for my new motor and tranny ideas. but if they could swap them out for that kinda money i would get an LS1.
#200
Car: 1991 Camaro
Engine: 2000 LS1
Transmission: 4L60E SS3600
Wrong. You do NOT need a 4th gen gas tank to use the LS1. You need an Aeromotive Fuel Pressure Regulator and your set...
