[For Sale] (IA) T-56 Bellhousing, Spec Stage 3 Clutch, Fidenza Aluminum Flywheel
SPEC LT-1 Stage 3 clutch (SC423) - 1000 miles on it (no bearing or alignment spline- $200 shipped
Fidenza Aluminum Flywheel w/new insert - 1000 miles on it - $200 shipped
You can see from the photos that the insert has very little wear. The car (when it ran) was street driven to and from work and the gym other than that the clutch never saw a drag strip or a hard launch.
The problem and the fix... - I have three steel thread inserts in it to repair the aluminum threads that were pulled out with the bolts the last time it was used. I will send the other thread inserts for any issue to whom ever buys this.
ARP 12 point crank bolts (330-2802, best part I can find to match, $34) for the flywheel, these are included with the flywheel
LT-1 T56 Bellhousing w/ slave mount and the bolts - $240 shipped
Buy it all together and I will sell it for $600 shipped (make an offer)
I went to an GMPP LS3 525 motor trans combo and do not need any of this. Transmission is gone already.
Thanks for looking
Thanks for looking
Re: (IA) T-56 Bellhousing, Spec Stage 3 Clutch, Fidenza Aluminum Flywheel
Reasonable offers will be considered...
price reduced
Prices adjusted
