[For Sale] LT1 T56 swap, AFR Heads, 280xfi cam, Holley Stealthram 383 short block, Ram clutch
Car: 1989 GTA
Axle/Gears: 9bolt 3.27s
SOLD==LT1 T56 6 speed trans with bellhousing (very smooth shifting), 4th gen pedals, electrical connectors, Hawks Thirdgen trans crossmember for 3rd gen fbody, Starter with bolts, GM clutch master cylinder and slave cylinder. All 6 speed swap parts for $1600obo
SOLD==LT1 Ram Power Grip clutch disc with pressure plate and through-out bearing (rated at over 500ftlb), with GM flywheel. Less then 2000 miles on this setup, $350obo
http://www.summitracing.com/parts/ra...w/make/pontiac
==Dougs (same design as Hooker) Long Tube Ceramic Coated Headers (part #D3321)1 3/4" with 3" collectors, custom 3" off-road Y-pipe into a single 4". All exhaust parts for $500obo
http://www.summitracing.com/parts/dou-d3321
SOLD==Mufflex exhaust with the MagnaFlow straight through race muffler option
==Holley StealthRam intake manifold with all vacuum fittings, throttle body and sensors, Holley fuel rail kit and Kirban Billet adjustable fuel pressure regulator, -6 braided stainless steel fuel lines with AN fitting for direct hook up to a 3rd gen fbody, The intake manifold was milled by LAM engines to fit under the stock GTA hood. Less then 50 miles. All intake/fuel parts for $500obo
http://www.summitracing.com/parts/wnd-7540/overview/
http://www.summitracing.com/parts/hly-534-186/overview/
http://www.kirbanperformance.com/pro...R+%236547.html
==AFR 195 Heads, upgraded 7/16" rocker studs, shimmed valve springs for .576 lift cam, excellent condition, Just gone through at LAM engines 50 miles ago, come with ARP head bolts, $1250obo
http://www.summitracing.com/parts/afr-1041/overview/
==Comp 280 XFI (230/236 .576/.570) small base circle to fit in a 383 stroker (will also work on non-stroked engine) Comp push rods, Comp Ultra Pro Mag Roller Rocker Arms, Roller timing set, roller hydraulic lifter. Less then 50 miles all parts. All parts for $400obo
http://www.summitracing.com/parts/cc...make/chevrolet
http://www.summitracing.com/parts/cca-12-467-8
==383 stroker short block(sbc, small block chevy), I need to pull the oil pan to be sure of the brands for each part but I believe they are SRP pistons, Scat crank, 6" Eagle rods. short block has about 10,000 miles on it, it was built by Kilpaticks in Waukesha. It has developed a very slight knock when warm (no sounds when cold). I'm sure you could freshen up the block with bearings and rings and it would be like new. $550
All parts came from a 1989 Pontiac Trans Am GTA but many parts can be used in other cars. See links for exact specs on some of the parts. I am looking to sell the parts as package deals before I consider parting things out. Any questions call 262-894-5664, NO texting please.
I am willing to deal if you are interested in more then one group of parts. The engine is assembled right now (oil pan-intake) if you are interested in buying it that way or I can disassemble
Car: 1989 GTA
Re: LT1 T56 swap, AFR Heads, 280xfi cam, Holley Stealthram 383 short block, Ram clutc
T56 swap, clutch parts, and Mufflex exhaust are SOLD
Car: 1986 Camaro, 2004 9c1 impala
Engine: TPI 350, previous owner hackjob
Transmission: built out 700r4
Axle/Gears: 4th gen, 373, LSD, GIRDLE
interested in trades? what part of WI are you located?
84z96L31vortec
08-20-2017 12:16 AM
