[For Sale] LS1 Corvette engine and Holley HP ECU
I have for sale an LS1 2002 engine with 4L60E trans and new Holley Hp ecu for sale for $4000. 29K miles. Original ecu goes with engine and trans but wiring was cut at firewall when removed. The throttle body is cable, not drive by wire which makes it easier to use. The trans comes with converter and flywheel. I want to sell with new Holley HP ecu with complete harness and wideband sensor and map sensor included also dvd with complete instructions and tuning. I prefer local pickup or will deliver no more than 75 miles otherwise shipping will be $350 to the Midwest region and $550 to New York and surrounding areas. I can recommend the best one if needed. I may even be able to get a better price on shipping. Any questions, email me or call Terry at 661-943-1739.
Want a title? Post!
Car: 1989 Z28
Engine: 5.7l TPI
Transmission: Auto 700R
Re: LS1 Corvette engine and Holley HP ECU
hello Terry was wondering if you could send some pics of the trans csheffler@saa-inc.com thanks in advance
Car: 1986 Trans am
Engine: 5.3 LM7
Transmission: T56 6 speed
Axle/Gears: Dana 44 w/ 3.55's
Just an FYI, thats not a corvette engine, and it's also not a 2002. It has the camaro/firebird oil pan and front accesories meaning it was out of an F body. Also, I can see that the exhaust manifolds and intake manifold has the provisions for EGR ports so it's a 98-00 engine.
FYI I did not mention it is a Corvette engine. I only looked at the numbers on the back of the block to see that it is a 2002 engine also.
