[Sold] (FL) LS1 Long Block
Car: 1989 Pontiac Trans Am GTA
Engine: cammed LS1
Transmission: Monster SS 4L65E
Axle/Gears: 9 bolt posi w/ 3.70 gears
(FL) LS1 Long Block
346ci LS1 long block assembly (all aluminum). The block casting number is 12561168 which indicates a 2001-2004 LS6 block and it has 241 heads which indicate 2001-2002. This leads me to believe it is an '01-'02 LS1. Anyways, it comes with the LS1 intake & TB, waterpump, & EGR. It doesn't come with the transmission (or related trany items), A/C compressor or bracket, knock sensor harness under the intake, intake bolts, oil pan, oil pan pick-up tube, windage tray, dipstick or sensors (other than the knock sensors). It doesn't come with anything else that you don't see in these pics just in case I forgot something. The guy said it ran great when he removed it from his wrecked T/A and I believe he said it had about 112,000 miles on it. I am asking $1000.00 o.b.o. +shipping if required.
Local pick-up prefered. Paypal or cash in hand. I will consider shipping. I think my local UPS store could crate it up for shipping.
I got a new fuel rail on my other engine. So I will throw the stock fuel rail in with the deal. I will probably be buying high flow injectors too. So I will be throwing the stock injector's in with the deal. I just removed the transmission yesterday and found a roller pilot bearing in the crank. So that is a little bonus for someone wanting to go manual. I will also throw in the stock torque converter that was on it and an engine stand if needed. I can post more pics if needed.
Engine: cammed LS1
Re: (FL) LS1 Long Block
Anyone interested at $800?
Engine: cammed LS1
Give me your zip code and I will get a shipping quote for you.
Engine: cammed LS1
I inquired about a quote for shipping today from UPS. I guess they have a freight company they use for stuff that big. They are supposed to call me back any time now with a price. I will let you know as soon as I hear anything.
Engine: cammed LS1
Would you want the stock torque converter too? It would just add more weight & shipping costs, but up to you. I won't be needing it. (This engine does not come with a flexplate in case I forgot to mention that above) I'm assuming you would want the injectors and fuel rail too Warnd? I'm just trying to make sure I have all of my ducks in a row
Car: 1993 GMC Typhoon
Engine: 4.3 Turbo
Transmission: 4L60
DHL used to be the best in domestic frieght, but i think they only do international shipping now..
Engine: cammed LS1
Yes, you are correct. They just called me with a quote yesterday afternoon. $750 for the pick-up, crating & shipping! I'm going to talk to my neighbors today. I think one of them works in the freight business. If not, I will call a freight company Monday.
Engine: cammed LS1
I just called engineshipping.com and they said it was going to be more expensive because you live on the island. He is going to call me back with a quote here shortly.
Engine: cammed LS1
No response from Warnd, so it's still for sale. I found some better shipping options if needed. Thanks guys for the input.
Engine: cammed LS1
I will get shipping quotes for Blitzd247 & you Timinsk, but Blitzd asked first. So he has dibs at this point Yeah, I thought it was a pretty good deal too. I was surprised that no one jumped on it quicker. Then I get two people interested in the same day. Go figure
Engine: cammed LS1
The price quote for all three of you was $245 for shipping. That was assuming residential deliveries with a lift gate required. I'm sure the rate would go down if you went to pick it up at a local terminal. I figured the weight on the long block @ 350lbs. too. I'm just guessing on that one. It would probably help the price if I took it to a local terminal as well. Any other better shipping options you guys want me to check into?
Engine: cammed LS1
My information is to the left under my name where it says location, but the sale is pending on the item and should be sold by the morning.
MoJoe
09-24-2015 09:12 PM
gixxer92
09-01-2015 04:32 PM
