89 Formula Odometer and trip stopped working at same time
Hey!
Just posting to see if i can get any ideas or maybe some help on my 89 formula 305 tbi as the odometer and trip meter both stopped working at the exact same time. I looked into it a little bit and didn’t see anyone else have this exact problem, but I have seen that the gears for the odometer and trip meter are horrendous and break quite often. Before I rip my dash apart I just want to know if it could possibly be the signal converter (I think it’s called?? I’m not familiar with any of this) and if there is any way of accessing anything without having to take the dash apart.
Thank you in advance!
Re: 89 Formula Odometer and trip stopped working at same time
The speedo cable could have broken (1st choice), the speedo gear in the transmission may have become stripped, the speedo/odo unit may had it gears stripped.
Engine: 4++,350 & 305 CIs
It's the little gear in the cluster.
a few threads on here about it.
A google search of thirdgen.org will bring up better results than using the search here.
Location: Franklin, KY near Beech Bend Raceway, Corvette Plant and Museum.
Car: 1992 Pontiac Firebird
Engine: 5.0L L03 TBI
Odometer Gears - Firebird Odometer Gear Kit
1985-1992 Pontiac Firebird/Trans Am Odometer Gear Replacement By Atlanta Speedometer, Inc
Also there are a ton on threads on here about this problem on Firebirds with detailed pictures and instructions.
Firebird Odometer - Broken, but is there a fix?
