4th gen power.seat 12v source
So I've seen a bunch of guys tap into the cigarette lighter for power going to 4th gen driver seat.
But i already ran a wire under the carpet into the wire channel and up to the fuse block. I have a few empty spots labeled "assy" and "batt" that i thought would be a home run....in either spot, the chair will work for a few, then pop the 10a or 15a fuse for either the radio or gauges.
Any suggestions?
Any suggestions?
COTM Editor
Received 1,933 Likes
Car: '89 Firebird
Engine: 7.0L
Re: 4th gen power.seat 12v source
Dismount the fuse box so you can get a look at the back side. Choose an empty fuse slot that has a big wire going to it.
Post #310 shows how I did it in my car. Please don't reply to that thread and keep the conversation here.
https://www.thirdgen.org/forums/ltx-...ml#post5964726
XxWickedz28xX (02-28-2022)
Car: 1986 IROC Z
Engine: 5.0 TPI
Axle/Gears: 3.23 Posi
Any suggestions?
Any suggestions?
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Why can't the power seat be plugged into where it's supposed to go?behind the kick panel next to the hood release.That's a 30 amp outlet
XxWickedz28xX (03-02-2022)
Most of the threads i found only mentioned tapping the cigarette lighter which I didn't want to do.
Next chance I get, im tapping that spot!
Engine: 5.0 EFI
ks like
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Any suggestions?
Any suggestions?
