Rear hatch struts that won't launch the glass to outer space
Old 02-05-2024, 09:57 PM
  #51
KITT87's Avatar
Car: ‘87 Base Firebird
Engine: 2.8 V6
Re: Rear hatch struts that won't launch the glass to outer space
Originally Posted by stoutblock
Opening up this thread again with a question. My rear window defrost is wired through my strut. Do these replacement struts have this wiring attachment provision?
Yeah, I imagine they all do but I can confirm 100% that the strong arm ones have it. There’s a little bushing where the strut connects to the hatch that you’ll need to swap over to your new strut.
Old 02-05-2024, 10:39 PM
  #52
stoutblock's Avatar
Car: 1989 IROC-Z coupe LB9 T5 G92 N10
Engine: LB9 with L98 cam
Axle/Gears: 9 bolt 3:45 (G92 G80)
OK, I just ordered a pair of the 4967 and crossing my fingers that they work for me. My current struts are not strong enough to lift the hatch off the contacts so the auto release just closes it again automatically. PITA!
Old 02-06-2024, 03:24 AM
  #53
TGO - 10 Year Member
BigBlock73's Avatar
Car: 90 IROC original owner
Engine: 5.7
Transmission: TKX
Yes
Old 02-06-2024, 05:31 AM
  #54
exiled350's Avatar
Car: 1987 Camaro Sport Coupe
Engine: 427ci Gen 1 Small Block
Axle/Gears: Strange60 4.10 Eaton Truetrac
Be careful with the cheap ones, I got a set a while ago and didn't think anything of it. They had the tabs so they must work, right... Ya no, I hit the button and it blew my 50A ignition prefuse. Turns out they're not properly insulated where it mounts to the body so it's a dead short. I ponied up the $90 for a pair of AC Delco ones with the contacts welded on to the strut like they should be. Haven't installed them yet but they look to be correct.
Old 02-06-2024, 02:28 PM
  #55
DEBt/a's Avatar
Originally Posted by Abubaca
Just chiming in here. As with others, replaced my 4900 with 4967. Standard 88 Iroc hatch/spoiler. Used to come up on it's own, and WAY too fast. Now it just sits there on the latch, hovering. Juuuust a little pressure and it'll come up, but MUCH easier to pull down too.
$15 a piece from Rock Auto.
Do you know if these 4967's would be a good choice for an 86T/A with the rubber aero spoiler?..I wouldn't mind having to give it a push..
Old 02-07-2024, 10:46 PM
  #56
stoutblock's Avatar
Where did you buy them and do you have a part number?
Old 02-08-2024, 08:00 AM
  #57
exiled350's Avatar
Rock Auto ACDelco 510509.
Old 02-17-2024, 01:57 PM
  #58
exiled350's Avatar
I installed the Delco struts today and the work correctly. The closing effort is not bad and it opens slow enough that it doesn't bounce or anything. The defogger grid works properly now too. You can see the welded tab on the bottom and riveted at the top. The maxpow one is what I originally got that are totally made wrong for this application and shorted the defogger feed.
Old 02-17-2024, 02:19 PM
  #59
stoutblock's Avatar
^^^ good to hear ^^^
I bought a pair of the strong arm 4967 but decided the AC delco looked closer to stock with how the defogger wires attached. Now I have both on the garage shelf but will be installing the Delco ones.
tbrownokcu
07-23-2018 10:15 PM
dougd88gta
01-24-2012 07:39 AM
Copchaser
05-16-2009 03:10 PM
panther
09-23-2004 10:18 PM
89_IROC-Z_350
07-20-2003 11:50 AM
Quick Reply: Rear hatch struts that won't launch the glass to outer space
