Door panel top trim speed nuts
Old 03-10-2018, 05:47 PM
Sweatlock's Avatar
I did a search but nothing came up - does anyone know the size or the part number of the inverted speed nuts used to attach the cardboard door panel to the black plastic top trim piece?
Thanks in advance
Old 03-11-2018, 08:20 AM
On Probation
TGO - 10 Year Member
sonjaab's Avatar
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
Re: Door panel top trim speed nuts
On my 84 the washers were slipped over the plastic studs and then the plastic stud ends are melted down to secure them and hold the door panel and top trim together as one piece. Both doors are done this way and appear to be factory.
Old 03-11-2018, 12:16 PM
Drew's Avatar
Received 1,054 Likes on 749 Posts
GM considers the panel and trim as one piece. The nuts don't have a part number in the door panel diagram. Auveco most likely carries something close if not the exact piece. My personal preference would be to obtain them from a donor car.
Choose wisely. Measure originals, pay attention to finish, you don't want the ones with sealer, etc...
Old 03-12-2018, 06:56 PM
Sweatlock's Avatar
Old 03-20-2018, 04:54 PM
JA411's Avatar
That's all they are you just flip them over and use a allen bit with a hole inside it. Snap-On part #'s S9614 is 5/16" and S6103 is 3/8". They are pricey!
JOE
camarotucker
03-20-2012 06:42 PM
Loudmouth
05-22-2005 12:14 PM
Scania
Aftermarket Product Review
11-04-2003 02:21 PM
KNTA4DNU
07-05-2001 10:02 AM
Quick Reply: Door panel top trim speed nuts
