Found these seatbelt sleeves
Car: 1987 Chevrolet CAMARO IROC-Z
Engine: 5.7 crate engine 300hp
Transmission: TH700R4
I feel lucky!!
Found these band new seatbelt receiver sleeves on Internet.
30$
Can't wait to install them!!
30$
COTM Editor
Received 1,941 Likes
Car: '89 Firebird
Engine: 7.0L
Re: Found these seatbelt sleeves
This might be a dumb question but how are they installed over the seat belt?
I will find out next spring. Car is already store for the cold season.
Probably unbolt seat belt receiver assembly from center tunnel and slip the end plate in from the top.
I just bought this stuff, cut to length and heat gunned it. Works perfect and pretty sure it can be painted for a perfect match.
https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
It's nice that reproductions are available, but it stinks that they're damn expensive for such a basic part.
See the hole just above the bolt hole? If you look at the stock receivers, there's a molded divot in the sleeves around that same point. If you slip a flat screwdriver into the sleeve through the bolt hole, and pry carefully the sleeve will break free and slide right off. There's a hole in the mounting tab that the sleeve is molded into. The plastic plug that comes with the replacement pins them back in place. I suppose a pic is worth 1000 words...
To anyone that doesn't have a Gray or Black interior -- these CANNOT be dyed. I have tried several times, with multiple coats of adhesion promoter. Dye comes off immediately when they come into contact with anything, particularly if the seat is moved forwards or backwards (which it has to be to install these).
