How to remove the top horizontal plastic part near window
Hi,
I want to change the Door Seal / Weatherstrip of doors.
I don't know how to remove the horizontal plastic part to be able to access screws under.
I don't see any screws, any option ... See picture to understand what part i 'm telling about ...
Thanks !!
Thanks !!
1 Post
Car: 89 IROC
Engine: l98 350 TPI
Axle/Gears: 373s
Re: How to remove the top horizontal plastic part near window
Remove the armrest, electronics, lock switch, (there might be a stray screw or two in the bottom part of the door panel to remove) pry the door panel away from the door all around. Roll down your window. Slightly tilt the lower portion of the panel away from the door, push the top towards the window and slide upward. Door panel off, the plastic is removed from the backside.
articwhiteZ
07-09-2016 09:40 PM
truckerz
31
04-27-2016 11:25 AM
