Rear seats
Rear seats
I recently bought an 84 and noticed the rear seats were separated but only passenger side has striker bolt... ? The driver side doesn't even have a spot for one... Also what are the 2 bolts for on the back of the seats??? I have a manual but I couldn't find anything in it about these things. As far as I know, the seats are original.
Car: 1991 Camaro RS
Engine: 305 TBI
Transmission: WC T5
Axle/Gears: Torsen 3.73
Re: Rear seats
The two bolts are from the shoulder seat belts, whoever took them out was kind enough to leave you the bolts
Car: 1983 Trans Am
Axle/Gears: Stock
Re: Rear seats
Here is a problem I could never figure why my back seats have two latches and only
one striker bolt. Maybe was missing from factory, kinda weird.
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
Re: Rear seats
'84 did not have rear shoulder belts, plus the interior plastics would be different.
There would also be a metal center bar on the bottom in-between the seats that hold the seats to the floor.
You can always peek behind the drivers side panel to see if there is a place for the striker. IMO, it's not likely from what I've seen so far.
Re: Rear seats
Those seats are from a 88-92 camaro split rear with shoulder belts. Someone changed the original seats
Re: Rear seats
So what is the best way to address this? Should I try and put a striker bar in on the driver side? I think I saw someone else post about that...
thanks for the help so far, people.
Bald_eagle_machine
Exterior Parts for Sale
03-01-2016 11:11 PM
