Does it happen to you? water inside
Car: 1989 Gray ttop GTA
Engine: 5700cc
Transmission: auto 700R4
Hi
I was this issue. When it's raining, you open the door, but some water that lyes on the top side of the door falls inside the car. See the image:
Vertically, the top side of the door is aligned with the interior of the car (see the red displacement). So when the door is open, the water falls inside.
It is normal? Does it happen to you too?
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
Re: Does it happen to you? water inside
Yes they are called drip edges. Yes when you open the door a little drips on the inside of the door panel and door sill. Ttop f bodies aren't the most practical wet weather cars.
