Anyone try recovering sail panels?
Car: 1987 IROC-Z
Engine: 5.7L TPI
Axle/Gears: Borg Warner 9 bolt with 3.27
Just curious if anyone out there has tried recovering their torn sail panels? If so, were you successful?
Car: 88GTA
Engine: 5.7TPI
Re: Anyone try recovering sail panels?
If you are talking about the speaker covers, yes I have. Piece of cake. Get the material from Classic Industries and some 3M spray adhesive and do it. Mine turned out fantastic. But I'm a perfectionist so I took my time!
Car: 1987 IROC-Z
Engine: 5.7L TPI
Sweet. I will give it a try. I have all winter up here in Michigan to screw it up. Thanks for the reply.
Car: 1982 trans am
Engine: LG4
Transmission: 4 speed manual
Axle/Gears: 3.23 gears
i tried to repair mine but the backing material was broke apart when i pulled them off, working on making some fiber glass ones.
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
I recovered mine last winter. I got the material from the local JoAnn fabric store, and some 3m spray adhesive from Walmart. It was really easy to do, but my panels were plastic, not the crappy fiberboard stuff I've seen in other thirdgens.
Before I covered them, I took a large plastic tree clip, like the ones used to hold the insulation to the underside of the hood and glued it to the panel where the clothes hook screw went though the hold the panel in place. Then I put the covering on it. Now I've got a nice smooth sail panel with no ugly hook there that I never used.
Car: 88GTA
Engine: 5.7TPI
Good idea with the coat hook!
Yeah, those Don Johnson days with the jacket are long gone......
Car: 1987 IROC-Z
Engine: 5.7L TPI
Thanks for the ideas. I'll try using my old Don Johnson jacket to recover those panels!
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Be sure the material you are covering is smooth as glass = sanding/etc.
because the spray adhesive will show every bump and line under it.
I just folded the material over the edges and secured it along the inside edge using close clips and glue.
Car: 1987 IROC-Z
Engine: 5.7L TPI
Appreciate the tip and your service to our fine nation.
Car: 1983 Z28
Engine: 385 Fastburn
I recovered mine with carpet, turned out great.
Car: 91 Camaro RS T-Top
Engine: 5.0 Tbi
I thought about carpet, cause mine were grey and didn't match the black interior, but decided that seemed a little thick and I didn't want to muffle the speakers at all. I ended up rattle canning them black, turned out good.
norcalz28
01-16-2017 03:37 PM
hotrodjames
12-15-2015 01:11 PM
heg1ll
Interior Parts Wanted
10-23-2015 02:00 PM
