92 camaro custom dash set up
Car: 85 iroc with 92 ground effects
Engine: 355 11.1 world product heads
Transmission: t56
Axle/Gears: 3.54 dana 44
I had looked around on here for ideas and finally built my own gauge set up after looking at other members.
I used 1/4 lexan (doesnt crack when drilling, way easier then plexi)
I laid all the gauge spacing out on my vinyl machine and tranfered that to lexan so everything was laid out even and fit inside the outside bezel
Gutted the old cluster but kept the hi/low and turn signal area. I used vinyl decals of arrow and chevy logo on the back side of the lexan. The turn and highbeam shine through just like factory and saved me from adding 3 aftermarket lights
I put the screws below the dash level and top is retained by two brackets from the back of the gauges to the cluster frame so no screws are seen when installed
Transmission: t56
Transmission: t56
Re: 92 camaro custom dash set up
autometer sport comp with led bulbs to backlight them
Fast355
12-02-2016 06:33 PM
kah992
08-19-2015 02:55 PM
Vintageracer
08-11-2015 08:13 PM
