Gauge face replacement - How much work?
Car: 91 Firebird
Engine: 305 TBI
How much of my dash has to come out in order for me to get the gauge cluster out? Not necessarily looking for a step by step, just wondering if the whole dash has to come out or just parts?
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
Re: Gauge face replacement - How much work?
Just the dash pad and guage bezel. Drop the steering column down as well. Have to remove lower dash trim under the wheel. You have an airbag, so unhook the battery first. Just loosen the nuts and lower it as far as you can without removing the nuts.
Car: 91 Firebird
Engine: 305 TBI
Transmission: Pro-built 700R4
I took the lazy route. I pulled the bezel and gauge lens off and just put a small piece of electric tape over the air bag light. Actually looks good and the tape isn't noticeable unless you stare directly at it.
Car: 91 Firebird
Engine: 305 TBI
Ya, I have tape over mine right now also. I have couple car shows coming up and I don't want the tape there. Besides, it gives me an excuse to change the faces
Car: 91 Firebird
Engine: 305 TBI
This may be a dumb question, but do the needles just pop/pull off? I don't want to take a chance at breaking anything....
Car: '89 RS, '89 Iroc
Engine: L03, LB9
Transmission: 700r4, T5
Axle/Gears: 2.73, 3.08
the needles just pull of, when swapping mileage rolls from my 115 to my 145 i broke the 115 pintle(sp?) that the needle sits on, the 145 needle popped off with little force
1 Post
Car: 1988 GTA
Engine: VIN F 305 TPI
Transmission: AUto
Horologist supply companies have special pullers for taking the hands off clocks and watches. Some are cheap and do the needle job easily with out breaking anything. There is a special procedure for taking the hands off stepper motor gauges. You need to replace the needle in the exact position that they came off or it will need to be recalibrate. Check for videos on the net on recalibration.
Car: 1986 IROC-Z
Axle/Gears: 4:10
It wasn't bad. I didn't have to take my dash pad out. I just lowered the column. Took about 6 beers to finish. Then i had to take it out about 4 times to stop the gauge needles from hanging up on it. The illumination is great, but I wish I would have went the autometer route. Maybe next time.
Ghettobird52
07-05-2024 11:18 PM
