Need help IDing seats
Car: 88 IROC
Transmission: 5 speed
Axle/Gears: G92
These seats came in a '38 Chev I bought and I was going to replace the foam in the left seat. I was told they were from a '78-88 Cutlass and ordered foam for that seat. Today I removed the upholstery and the foam is completely different. Now I'm told they may be form a 3rd gen F-body but I can't find any pics of a seat like this. It is all cloth and the cover for the recline hinge is also matching in a velvet type covering. I can see an imprint on the side of the headrest where they did have a hook or loop for a shoulder belt too.
Any help with what they are out of will be appreciated...
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: Need help IDing seats
They appear like 2nd gen Camaro Seats,it looks like the head rest is all one piece.
http://www.ebay.com/itm/1977-CAMARO-...c7b217&vxp=mtr
Car: 88 IROC
Axle/Gears: G92
Mine are at least '78 or newer. The headrest is a different shape and the back is all cloth with a zipper closure. The replacement upholstery vendors list the zipper covers for some 3rd gens. I haven't found any f-body seats that are all cloth, so it's confusing.
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
Yes, those are the basic third gen buckets, came with many variations in color, pattern and materials. Many pictures on this forum.
Hawks has them:
http://www.hawksthirdgenparts.com/pr...placement.html
Hawks has them:
Car: 83 Z28 Crossfire
I have the same seats in my 83 Z28 identical in design to your pics but mine are gray. I think they were standard seats in the 82-83 Fbodies.
Car: 88 IROC
Axle/Gears: G92
Thanks...
Got contact info for Alex at PUI? I'm thinking of ordering the same
Car: 88 IROC
Axle/Gears: G92
PUI doesn't sell directly to the public. Once we knew what I needed, I ordered the upholstery from a local dealer. The dealer happened to have the foams on hand because of a return situation, so I got a smoking deal on them...
Can you post pics when finished? I'd like to see them
Engine: 5.0 EFI
This upholstery was made by PUI,purchased through Classic Ind.
Car: 88 IROC
Axle/Gears: G92
I just finished them Friday. What a PITA !! I'll never buy pre-made foam again. None of the wire stays in the foam were where they needed to be to match the originals or attach the listings. I spent a LOT of extra time butchering the heavy rods that are re-used for the new upholstery to get them to work with the ill fitting foam. The upholstery itself wasn't made exactly like original and has fitment issues as well. The seats are done and I will use them for a while but I really regret not having them rebuilt by the shop that made my headliner.
Here's the passnger seat. It looks OK at first glance.
The tabs sticking out at the bottom of the cushion should have been sewn on the full length. Here's a few pics of the poor quality of fit.
The tabs on the back of the backrest are not correct either and stick out like wings instead of folding down out of sight.
Car: 88 IROC
Axle/Gears: G92
[/QUOTE]
[/QUOTE]
Engine: 5.0 EFI
I don't understand why you should pay for the return trip on an inferior product!!!!Who did you get them from??
Sorry to hear that you had problems with the covers. That's the pattern and color I'm looking for do you have the part number?
